Tacoma Prerunner Locker Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Oct 1, 2024.
  1. Oct 1, 2024 at 8:16 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
  2. Oct 1, 2024 at 8:24 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The locker and non locker axle housings are different, you would need a whole axle to swap out.
    AllTacosFloat and TnShooter like this.
  3. Oct 2, 2024 at 3:22 AM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    The carrier assembly in the 3rd member is the part that does the "locking", locking the two axles together. The gears are what get locked by the carrier, so changing gears has no impact on whether your carrier locks.. If you know what you are doing, you can pull the 3rd member and then replace the carrier with the locker of you choice (pneumatic, electric, lunchbox etc)
    You can also buy complete 3rd members with the locker installed and then just swap the 3rd member. Check out East Coast Gear Supply. Or as mentioned above, you can swap out the entire rear end.
  4. Oct 2, 2024 at 9:05 AM
    TacoBell07
    Four door 2wd Taco
    Sounds like I would be unbolting the leaf springs then to take the whole mother out of there, in that case i guess there really be no disassembling or reassembling of the actual differential and the accompanying axle gears.
  5. Oct 2, 2024 at 11:31 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    you should be able to disassemble the 3rd member to change the gears. But no, you cant just bolt on a locker. You would have to get a 3rd that has a locker already
  6. Oct 2, 2024 at 11:36 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you replace the whole differential, Remember that the 4 cyl trucks had 4.10 gears.
    The 6 cyl trucks and 3.73
    You don't to make the 2.7 any weaker than it already is.....
    JAGCanada likes this.
  7. Oct 3, 2024 at 11:50 AM
    TacoBell07
    Four door 2wd Taco
    Have a Prerunner so I wont be using any parts for rear end off a 2.7 liter Taco but thanks.
  8. Oct 3, 2024 at 12:07 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I think he was getting at the fact we don't know what you have. The prerunner came with both engines as options. Which one do you have?
    TnShooter likes this.
  9. Oct 3, 2024 at 12:43 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Either install a locker of choice in your current 3rd member or replace the entire axle assembly from a 2nd gen that has a locker in it(trd Offroad model) youll then have to run the wires to activate the locker and a switch.
  10. Oct 7, 2024 at 9:50 AM
    TacoBell07
    Four door 2wd Taco
    Prerunner V6. They made Prerunners with 4 cylinders too ?
  11. Oct 7, 2024 at 9:51 AM
    TacoBell07
    Four door 2wd Taco
    What you mean by 3rd member Im a GOLD member. You mean the axle gears or the pinion gear ?
  12. Oct 7, 2024 at 10:07 AM
    TnShooter
    Deogee
    STOCK
    Yes. They made a 4 cylinder PreRunner.
    Most were manual transmissions.
    I owned one, it was a great truck.
    Easy to work on. But it didn't have much power.
  13. Oct 7, 2024 at 10:23 AM
    TacoBell07
    Four door 2wd Taco
    They made too many versions its confusing on top of fact that apparently they made 4 cyl Prerunners I have a Prerunner V6 thats 4 doors and long bed. Then get into crew cab, full cab, half cab access, non-binary cab its crazy. They should just made each cab a different trim.
  14. Oct 7, 2024 at 10:35 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    There's only 4 possible cab/bed configurations.
    Regular Cab Long bed
    Access Cab Long bed
    Double Cab Short bed
    Double Cab Long bed
    Pre-Runner is just Toyota's term for a 2wd truck with a 4wd suspension, both Pre-Runners and 4wd trucks are 6 lug. Non Pre-Runner/4wd trucks are 5 lug.
    Your axle code is on the VIN tag inside the door, there's an axle code list floating around on here somewhere. @TnShooter probably knows where it's at.
  15. Oct 7, 2024 at 10:45 AM
    TnShooter
    Deogee
    STOCK
    https://www.tacomaworld.com/threads/2005-2016-tacoma-axle-codes.408019/#post-11465611
    All the 4.0 - 6 cylinder trucks had 3.73 gears, EXCEPT the X-Runner. ;)
  16. Oct 7, 2024 at 10:48 AM
    TacoBell07
    Four door 2wd Taco
    ShooterG what does this mean? I still havent determined whether i can just take all gears and axles from a TRD and transfer them into my rear end housing.
  17. Oct 7, 2024 at 11:26 AM
    TnShooter
    Deogee
    STOCK
    No. You can not.
    There have been members claim you can swap the 8" carrier into your differntial housing IF you grind down areas in the housing.
    But I never done, never seen it done, and I would never do it.
    FWIW, the differential in your truck is stronger than the TRD E-Locker.
    Your truck is a 2008, if it has a LSD in it now, the E-locker will be WORSE unless it's locked.
    I'd go with a truetrac and be done with it. No buttons to push and you'll have good steering.
  18. Oct 7, 2024 at 6:31 PM
    Tahoeshateme72
    Tahoeshateme72 New Member
    Mark
    2008 SWB X Runner
    Trd bbk, short throw shifter.
    Trd sport has the lsd. Sr5 pre runner is peg leg. Same housing and gear ratio.
