Tacoma Problems
Discussion in 'New Members' started by pgoble, Jul 5, 2018.
  1. Jul 5, 2018 at 6:11 PM
    pgoble
    pgoble [OP] New Member
    Phillip
    Tacoma
    I have a 03 tacoma and I am having problems with the AT not shifting right, sometimes I have not reverse, here is the kicker I can plug in my OBDII code reader and my transmission shifts just fine. Any help would be greatly appreciated.
  2. Jul 5, 2018 at 6:15 PM
    sbrady
    sbrady Well-Known Member
    S. Polychronopolous
    MagGreyRC
    Fluid?
  3. Jul 5, 2018 at 6:19 PM
    pgoble
    Phillip
    Tacoma
    I just changed the fluids and the shifting silinoids and made sure the fluid levels on my truck are full. I was wonder if it could be an electrical problem with ecu.
  4. Jul 5, 2018 at 7:15 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW... While I’m not a mechanic, I’m sure someone will be able to help you out here. You should also check out the 1st Gen section on this topic.
  5. Jul 5, 2018 at 8:17 PM
    pgoble
    Phillip
    Tacoma
    I sure hope so, I have changed the shifting selinoids and the fluid and the filter, I was wondering if it could be ECU, because when I plug in the OBDII reader it shifts just fine.
