Tacoma pulling to the left afrer 33's put on
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Sr5Chris, Feb 12, 2012.
  1. Feb 12, 2012 at 10:36 AM
    95Sr5Chris
    95Sr5Chris [OP] Active Member
    CT
    1995 Tacoma Sr5
    Just put on 33x12.5s. Had to do the Pinch weld mod, ( thanks for the help guys). Anyway the wheel is a little shakey while driving and when i put on the breaks it pulls to the left hard. All 4 tires are around 24-25 PSI. Any sugestions. maybe rebalance?
  2. Feb 12, 2012 at 10:37 AM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    Sounds like either it's out of alignment or one of the tires is not balanced right like you mentioned.
  3. Feb 12, 2012 at 10:39 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Pulling during braking usually means a caliper or pad issue.
    Shaking during driving is usually a tire balance or front end alignment issue.
  4. Feb 12, 2012 at 11:28 AM
    95Sr5Chris
    CT
    1995 Tacoma Sr5
    just had an alignment done about 3 weeks ago. My 265s drove fine. Im hoping it's a tire balance issue
  5. Feb 15, 2012 at 5:58 PM
    John Cheong
    John Cheong Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    pulling when your braking can indicate a suspension problem. usually the side that it pulls to is the good side. try checking out the suspension on the opposite side it pulls too
  6. Feb 29, 2012 at 5:07 PM
    95Sr5Chris
    CT
    1995 Tacoma Sr5
    well you were correct. Left caliper was frozen up, Replaced both and pads, drives completely different.... one thing i noticed was the gas gauge. lol.
    thank you guys
