Tacoma pulls hard with Lower Pro Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ckossel, Nov 19, 2010.
  1. Nov 19, 2010 at 12:26 PM
    ckossel
    ckossel [OP] The Veekness
    Chad
    Phoenix, AZ
    07 PreRunner TRD
    22" BOSS wheels TRD Exhaust CAI - K&N Aircharger
    I have a 2007 DCLB that I placed 22" wheels with Sumitoma Tires. I noticed because of the wider tires and light Tacoma body that it pulls to the crown or terrain of the road very easily - sometime making it hard to control. Is there anything that you can put on the truck to eliminate this pull so much? the measurement of the wheels are: 305/40R22 - 114H
    Thanks!
  2. Nov 19, 2010 at 12:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I would go and have it aligned.
  3. Nov 19, 2010 at 12:32 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Maybe steering damper? Mine does the same thing, not as bad as what you're describing but it pulls pretty bad at times. My alignment checked out fine also.
  4. Nov 19, 2010 at 4:05 PM
    ckossel
    Chad
    Phoenix, AZ
    07 PreRunner TRD
    Alignment is just fine.... I think it may be something with the steering damper and the tread of the tires gripping the road. Was hoping to get some good feedback - thanks!
    anyone else?
  5. Nov 19, 2010 at 4:09 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Does it always pull the same direction? Or is it terrain dependent? A steady pull alway the same direction (e.g. left) - That could be the alignment or the tires.
  6. Nov 19, 2010 at 4:17 PM
    Pugga
    Massachusetts
    If you have an extremely grippy tire, maybe an alignment, but not at the factory specs, would help. Something more similar to a set-up you'd see in a sports car. You'd have to talk to someone who really knows there stuff to recommend a new setting, if it would even help at all.
  7. Nov 19, 2010 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wide tires, plus little Caster = pulling when the tires hit uneven pavement.
  8. Nov 19, 2010 at 4:46 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Ditto, when I stated get an alignment I mean get one that suits the characteristics of your vehicle.
  9. Nov 19, 2010 at 4:47 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Mine followed the ruts in the road with the stock rugged trails. After getting a 2" lift I had it alighned a few times and it got better but was still very noticable. If I drove close to the center line it veered to the left and when driving closer to the shoulder it veered right. Going down freshly paved roads it tracked straight as an arrow. After getting new tires (E rated BFG A/T's) the problem is now pretty much gone. I not sure but it seems either the higher psi (40 front/36 back) or the stronger sidewall helped.
  10. Nov 19, 2010 at 4:49 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    go to a normal rim size for a tacoma
  11. Nov 19, 2010 at 4:55 PM
    Pugga
    Massachusetts
    If it's constantly pulling to one side you're alignment is most likely out.
  12. Nov 19, 2010 at 4:58 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Under acceleration?
  13. Nov 19, 2010 at 5:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. Im betting its because you have a front drive Tacoma.....
  14. Nov 19, 2010 at 5:00 PM
    JDMcQ
    X2
  15. Nov 19, 2010 at 5:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Have you been checking your milage? Im bettin, your gonna see an improvement.....
  16. Nov 19, 2010 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah.....Hows the drive from Fro?
  17. Nov 19, 2010 at 10:06 PM
    tervanun
    tervanun Well-Known Member
    Dan
    Las Vegas
    "Shirley" - 06 DC 4x4 SR5
    Installed: 6in procomp, 17's, 35" BFG K02's, Stubbs HD-SKO sliders, Brute Force Fab front bumper, XRC Winch. Mods to come: Brute Force rear bumper, Fox Coilovers
    -low pros don't flex much compared to stock or offroad tires.
    -if they're "high performance" they will flex even less
    -if your truck follows the grooves in the road too much,
    your tires are too wide and stiff for the size of the truck.
    There isn't much of a fix for it.
    I had the same thing happen (low key) in my first car - honda accord coupe with wide lo pros on it
  18. Nov 19, 2010 at 10:10 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
  19. Nov 20, 2010 at 4:54 AM
    JDMcQ
    The wandering, or pulling is an attempt by your truck to drive into a pole and kill itself because you put 22's on it.
  20. Nov 20, 2010 at 6:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OR.....the truck trying to get everyones attention to check out how nice it looks?
