Tacoma Quirk?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBazinga, Sep 7, 2014.
  1. Sep 7, 2014 at 5:11 PM
    TacoBazinga
    TacoBazinga [OP] Well-Known Member
    Dana
    Belchertown, Massachusetts
    2014 DCSB Manual, Magnetic Grey
    TRD Exhaust, Short Throw Shifter, Bead Lock Wheels, Undercover LUX cover, TWM Performace Desert Eagle shift knob
    I'm wondering if anyone else with a taco has this quirk. Out of the three climate control dials (fan speed, temperature, and output location), the fan speed control dial has a slight spring give to it if you push on it. I discovered it on my '06. I traded it in this year for my '14 and it exhibited the same quirk - the fan speed dial had the same slight springy feel with pushed! Odd coincidence considering the number of years between the models...
  2. Sep 7, 2014 at 5:15 PM
    boramkiv
    boramkiv On-Roader
    Trying to leave the asphalt
    Chesapeake VA
    TRD Sport
    Are you actually pushing the dial or do you mean turning?
    It is a bit hard to keep it between speeds, I'm sure it's designed that way to not confuse the motor.
    The spacing between speeds are pretty huge too. Nice design, simple but nice.
  3. Sep 7, 2014 at 5:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Can't say I've ever noticed it. But I've never pushed in on the switch either.
    I'll try it next time I get in the truck and let you know.
  4. Sep 7, 2014 at 5:18 PM
    boramkiv
    boramkiv On-Roader
    Chesapeake VA
    TRD Sport
    Ohh well, I guess I never pushed the dial in. Will have to check that out.
  5. Sep 7, 2014 at 5:21 PM
    TacoBazinga
    Dana
    Just pushing it. In my '06, I remember I discovered it when I was changing the speed and hit a bump and felt it push in slightly (not trying to split speeds). It's not a problem at all, just an endearing quirk :) It's just a very slight give.
  6. Sep 7, 2014 at 6:16 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
  7. Sep 8, 2014 at 8:04 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Tried it on my 2014 DCSB. It happens.
  8. Sep 8, 2014 at 10:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is because the type of switch used. It has an internal spring ( inside the switch ) that maintains contact pressure. Common for this type of switch ( Multiple contact rotary switch ).
  9. Sep 9, 2014 at 3:07 AM
    TacoBazinga
    Dana
    I would think the same type of switch would be used for, at least, the output control switch...
    Anyway, thanks!
  10. Sep 9, 2014 at 3:57 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    The switch is able to push in, and that bugs you?
    Just what till you find the real "quirks"
  11. Sep 9, 2014 at 9:44 AM
    TacoBazinga
    Dana
    Nope, doesn't bug me in the least - in fact, it's rather endearing. Just thought it was funny that the same switch had the same characteristic as my old '06.
  12. Sep 9, 2014 at 8:03 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The Temperature switch is a variable resistor and not a switch at all.
  13. Sep 10, 2014 at 2:56 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    My 14 does it. Maybe 1/16 an inch.
  14. Sep 10, 2014 at 5:21 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Keep it up while the fan is running and you'll be buying a new control.
