Tacoma rattle in back
Discussion in '4 Cylinder' started by dgjones, Jul 27, 2009.
  1. Apr 16, 2011 at 9:38 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My '05 developed a rattle and it was one of the 4 bolts that hold the bed down... Simple tighten up (need special socket)... problem solved!
  2. Apr 17, 2011 at 3:56 AM
    TacoBirr
    TacoBirr Member
    Greg
    SW Ontario
    05 Taco DblCab TRD Off Road
    I just don't see now those bolts could loosen. Mine looked loose but I had to use a 3' extension to remove it. If I had just tightened it instead of inserting that rubber spacer I mentioned, the bed would be twisted, which is visible from behind the truck (anyone following me could plainly see the bed wasn't level with the cab back window).
    If I wanted that I woulda bought a Ford.
  3. Aug 30, 2011 at 7:37 AM
    Son of Liberty
    Son of Liberty Active Member
    Tennessee
    Tacoma
    Thanks y'all. I had this same issue after driving through some heavy brush this weekend. I thought I might have knocked something vital loose, but it was just the spare tire. I feel a little silly for not checking that until after reading this post...
    My leaf springs are extremely squeaky and the front end is noticeably lower than when I bought the truck. I hope to be installing a full OME lift soon.
  4. Sep 5, 2011 at 10:14 AM
    charlesc23456
    charlesc23456 Member
    usa
    Tacoma
    It is the leaf springs. I have a 2011 Taco that does the same thing. The service tech told me it was the leaf springs.
  5. Apr 18, 2012 at 12:53 PM
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    i notice a similar rattle. will be checking spare and leaf springs. thanks for the advice.
  6. Dec 15, 2012 at 6:00 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    my 13 has this rattle i will be c clamping the leafs tommrow soo annoying.
  7. Mar 31, 2013 at 12:13 PM
    BeEatNU
    BeEatNU Well-Known Member
    Nick
    Gardena, CA
    2013 Tacoma Double Cab Limited
    I figured this is my problem too.
    I have a 2013, I just changed my leafs to Deavers so they need to get broken in.
  8. Aug 16, 2013 at 9:03 AM
    Parrothead1809
    Parrothead1809 Well-Known Member
    My 2010 TRD Short Bed Double Cab with 8k miles has the same rattles - although I sometimes get the feeling it comes from which ever wheel is currently hitting the pot hole (ie: even the front). Is there any sort of test to confirm the shocks are all working per spec?
    I have yet to check the bolts in the bed. I have crawled underneath to see if the spare is loose (it isn't) but I haven't tried actually dropping the spare and re-attaching it.
    Regarding the leaf springs - How can I determine that they are the root cause and what piece of them would be rattling ?
    Thanks,
    -PH
  9. Aug 16, 2013 at 9:17 AM
    Twirlin
    WI
    Check the bed bolts. That was the cause of my rattle.
  10. Oct 3, 2016 at 7:50 PM
    Kimu5855
    Kimu5855 New Member
    Vinnie
    Hilo Hawaii
    2011 Tacoma 2wd and 2013 Xrunner
    Guys, regarding this rattle under or in the bed. I think the bed bolts bottom out and area below bed wears out so this then requires a washer. I can see a gap when lifting the bed.
    I replaced both leaf springs, shocks, bumper 2x, removed the bed and campertop, and fender flares. Noise still there and i considered replacing axle bearings at the hub. I will install 3/8" rubber washers below bed.
    Vinnie
  11. Nov 9, 2017 at 3:21 PM
    TotallyUnqualified999
    TotallyUnqualified999 New Member
    Team,
    My 2014 DCSB Baja was rattling over bumps. It sounded like a plate of metal rattling against another plate of metal. Turns out it was the beadlock plate rattling against the rim (I have the TRD wheels). I wish I could say it didn't take me a month and hours of googling and crawling under the truck to find the solution that was right in my face as I checked brakes, heat shields, suspension, etc... lol.
    My only consolation is I took it to the shop for something else and asked them to look into the rattle - they didn't find the cause either.
    I haven't seen the beadlock plate mentioned in any of the rattle threads, so wanted to post about it.
    -boom
  12. Jul 30, 2020 at 2:33 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    I hate random rattles. I have a new one, too, from all the offroading.
    Mine sounds almost like metal taping metal, or like the entire rear window rattling on occasion, like when braking or hitting bumps.
    Sounds like this is inside the truck, in the back right side.. like the rear window. I've checked behind and under all the seats, the trim, door panels. I'm losing my mind.
    My OCD is winning. Ughhhh. Ideas????
  13. Oct 2, 2020 at 3:28 PM
    cdthiker
    cdthiker Well-Known Member
    Tim
    WAY north Idaho
    2012 Tacoma RC 4X4 5speed
    1 check the bed bolts. one came loose on mine in the first 20k, had the dealer tighten it up under warranty right before it ran out. a few months later the rattle was back. guess they tightened it too much and messed the holl it went through in the bed up a bit. but because they had done it they ended up putting in whole new inner bed for free. sweet deal since the truck was out of warrenty by then.
    2 check your exhaust. on my 2012 there is a section where if you hit a big bump part of the piping will move up. aka one of the rubber hangers will flex, then snap back and pull the pipe up too high and it then rattles like a mother on the metal it is hitting. when the exhaust is cool, just grab onto it and yank stright down. will pop the exhaust into place no more rattle
    good luck
  14. Jul 30, 2022 at 5:03 AM
    SkinnyT
    SkinnyT Member
    My 2016 DCSB off road recently started rattling from the rear. Same as all of you, it sounds like metal plates quickly banging together. Check the u-bolts and leaf springs yesterday and they seemed good which lead me here. I guess I'll take a look at the bed bolts and the cap on my TRD wheels.
