Tacoma rear 1” lift
Discussion in 'Suspension' started by stockprerunner, Feb 25, 2020.
  1. Feb 25, 2020 at 11:28 PM
    stockprerunner
    stockprerunner [OP] stock truck
    las vegas,nv
    2014 limited 4x4
    Trd supercharged
    So i’m debating on getting a shackle kit for my truck to get a 1” lift in the rear. ive never been a fan of blocks. what are some other options i have? it seems if i go flip i have to replace a lot of other parts. i don’t do any rock crawling so i’m not sure if a flip would be worth it. is their any aal that will get me 1”? or any suggestions or other ideas i could go with?
  2. Feb 26, 2020 at 7:56 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Just put a 1” block and call it it day. Easy, cost effective and does the job.
    PuyallupJon and In&out like this.
  3. Mar 2, 2020 at 9:38 AM
    Walkdog
    Walkdog Member
    2017 TRD OR
    All the AALs I know of are going to lift more than one inch, unfortunately.
    Deaver will customize one of their packs to your desired specs for $150, though. Pretty sure the guy you want to talk to there is named Jeff.
  4. Mar 3, 2020 at 12:34 PM
    Samurai Tech
    Samurai Tech Well-Known Member
    2017 Tacoma SR5 Dbl Cab 4X2
    Anyone know if a 1" block will require a longer shock ?
  5. Mar 5, 2020 at 6:20 PM
    stockprerunner
    las vegas,nv
    2014 limited 4x4
    Trd supercharged
    yea. bilstien 5100s and fox 2.0s allow for 0-1” of life. will cost around 170-200 for those shocks. their cheaper shocks out their i’m sure.
  6. Mar 5, 2020 at 6:22 PM
    Bishop84
    Bishop84 Well-Known Member
    Factory shocks can handle 1", but if you want full travel, the 5100 is the easiest solution.
    There's thousands and thousands of tacomas with 1" blocks and stock rear shocks out there.
