tacoma Rear Brake adjuster
Discussion in 'New Members' started by jonnie 5, Nov 8, 2021.
  1. Nov 8, 2021 at 7:21 PM
    jonnie 5
    jonnie 5 [OP] New Member
    Jon
    2001 tacina 2,4 L 2 wheel drive
    None
    Ive owned my tacoma since november 2000, and this is the first major work Ive had to do.
    the oil seal on the right rear started leaking after 208000 miles, so i decided to replace the wheel bearings and seals on both sides. After previewing several videos I found none of the axle assembly exactly like mine. when I got around to replacing the shoes I found the automatic adjuster assembly was no exception, The pin that hold the levers to the shoe was much larger and has no and has no step in it. My question is was I given the wrong shoes or do I need to replace the auto adjuster assembly and spring ? The parts dealer swears they are the right shoes.
  2. Nov 8, 2021 at 7:51 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Sounds like you got 6 lug shoes.
    You have 5 lug
    buckhuntin-tacoma likes this.
  3. Nov 9, 2021 at 4:44 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
