Tacoma rear camera not working after disconnecting battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ReconMarine, Sep 5, 2019.
  1. Sep 5, 2019 at 5:17 PM
    ReconMarine
    ReconMarine [OP] Well-Known Member
    Ed
    2019 White Tacoma TRD Sport
    Hey. I disconnected the negative battery terminal when installing the kicker dash speakers on my 2019 Taco. After connecting the negative wire back my reverse camera no longer is working. Install took no more than 40 mins. I do have a Front Rear Anytime Camera harness installed but that should not be an issue. IS there a reset that has to be done? WHen i put it in reverse now it shows a top view of the truck when i get near to an object but no camera. I looked on Youtube and on this site and no luck.
    Any thoughts? Thanks
  2. Sep 5, 2019 at 5:21 PM
    GrayTacoma
    GrayTacoma Well-Known Member
    Andy
    Huntingtown, MD
    2011 TRD off road
    PIAA ion yellow fogs stay on all time,aux reverse lights, aux lights, camper with rack, cb, air bags, on board air, aux fuse box, aux batt, CAI, etc.............
    Turn the key off and check in 30 minutes.
  3. Sep 5, 2019 at 5:26 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I did a CMC for someone that had that happen as well (disconnected the ground to weld). You have to disconnect the front anytime harness, start the truck and plug it back in. I'm pretty sure that's what he told me. It was a series of steps that included unplugging the harness and plugging it back in.
    Mtbkrguy likes this.
  4. Sep 5, 2019 at 5:48 PM
    Mtbkrguy
    Mtbkrguy Well-Known Member
    2016 Tacoma TRD Sport 4x4 Double-cab
    Yup I've had the same issue. Connect battery. Unplug Anytime harness completely, plug back in and it should be good. It will happen anytime you disconnect the battery and reconnect.
    GHOST SHIP[QUOTED] likes this.
  5. Sep 5, 2019 at 6:03 PM
    ReconMarine
    Ed
    GHOST SHIP and Mtbkrguy, That worked :) Removing the FRAC and then turning it on after plugging back the stock camera did the trick. Everything is back to normal and i have great tunes now. Thanks for the quick replies :cheers:
    ancient11 and GHOST SHIP like this.
  6. Sep 5, 2019 at 7:17 PM
    GHOST SHIP
    GHOST
    Finally, a quirk on a third gen I know how to fix.
    :fistbump::bananadance:
