Tacoma rear disc brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toms2014, Dec 10, 2016.
  1. Dec 10, 2016 at 2:18 PM
    toms2014
    toms2014 [OP] New Member
    Tommy
    4-dr Tacoma Prerunner
    LED lights
    Will Toyota 4Runner rear disc brake assemblies: caliper mounting brackets, calipers, & discs fit on the rear axle of a Tacoma?
  2. Dec 10, 2016 at 4:52 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    :popcorn: now that's a good question. does the 4runner come with the e locker?
  3. Dec 10, 2016 at 4:54 PM
    Pigpen
    Dan
    Northwest Montana
    It's been done. Try the search function or google
  4. Dec 10, 2016 at 5:00 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Did it INCREASE stopping distances like some of the other swaps?
  5. Dec 10, 2016 at 5:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  6. Jan 23, 2017 at 11:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    4Runner caliper and disk.
  7. Jan 23, 2017 at 1:31 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    That set ups look sweet!
