Tacoma redesign wish list
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stlfun88, Nov 11, 2016.
  1. Nov 11, 2016 at 5:56 PM
    #41
    Clearwater Bill
    Billy
    Largo Florida
    1st gen style
    2nd gen size
    Less gadgets.
    2 speed rear axle.
    Lower cost.
    Be able to actually order a vehicle like you want it. Not get 'close' with 'packages' and port special items.
    rz2mbc likes this.
  2. Nov 11, 2016 at 6:56 PM
    #42
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    The Off Road access cab 4x4 is not available in the USA in a manual, only in double cab. But Canada gets the OR 4x4 access cab in manual. If I could get this configuration, I would trade mine in for it.
    shakerhood likes this.
  3. Nov 11, 2016 at 6:57 PM
    #43
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yes the 4x4 OR is available with a Manual but ONLY in a Double Cab!
  4. Nov 11, 2016 at 11:47 PM
    #44
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    My F'ing Shin Has Banged that damn sharp edge on the lower driver side dash. I do it 3+ times a week and sit in silence for a good min or two cause I cant believe I just did it again. I thought I was the only one. F that corner.
    venezian likes this.
  5. Nov 12, 2016 at 1:47 AM
    #45
    AZ Tacoma
    AZ Tacoma Well-Known Member
    Tucson AZ
    2015 Tacoma DCSB 4x4 TRD OR
    OME 884x coils, Icon AAL, Bilstein 5100 shocks, P265/75/R16 tires
    Put the 4Runner engine in and add direct plus port fuel injection. Put 4.30 gears in auto trans truck. Add HID headlights and fogs. Go high strength steel frame. Aluminum body and truck box to help save weight and prevent rust. Add rear coil springs and design for 500 pounds more payload. Add manual seat height adjustment. Plus rear disc brakes. That would be reasonable and perfect.
  6. Nov 12, 2016 at 11:05 AM
    #46
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    :thumbsup:
    jonnyozero3[QUOTED] likes this.
  7. Nov 12, 2016 at 11:36 AM
    #47
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I bet we see this in the 3G sooner versus later. The TRD Pro grille has a piece that looks like it can be removed to hold something electrical, which would make sense if it were some sort of forward facing item for something along those lines.
  8. Nov 12, 2016 at 1:45 PM
    #48
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Or you could simply pay attention to your surroundings....
  9. Nov 12, 2016 at 2:39 PM
    #49
    offthewallsurfer
    offthewallsurfer Well-Known Member
    I stand corrected... you are absolutely right. Only the TRD Sport is available in the access cab with the 6 MT configuration.
  10. Nov 12, 2016 at 3:32 PM
    #50
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    Mine would have to have.
    A) Usb power source for the go pro and maybe a 2nd mount looking out the back.
    B) Built in brake controler
    C) higher shin clearance. (Im long legged but I have to sit back in the seat like a car rather than a truck) i dont hit when i get in, only when i shift gears.:burnrubber:
    D) more guages or dash menus to see (volts, oil, etc)
    E) 110v in cab outlet
    F) Sliding center consol armrest. mine is an elbow rest. also make it lockable.
    G) Driver side handle
    H) coin holder
    I) cruise control buttons, not the little stick behind the wheel
    J) lights and 12v power source in the bed.
    K) Remote tailgate lock on the key
    L) built in compressor (maybe with airbags/CTIS/airhorn?)
    M) power/extendable mirrors (similar to the ones on dodges)
    N) tonneu cover needs to have the strap locks for when only 1 section is pulled back
    O) engine bay light and hood shocks.
    Id like to see at least a different knob. One that wont turn unless you push in on it or something. I put a sticky note over top of mine, so I dont turn the wrong one.:frusty:
  11. Nov 12, 2016 at 4:56 PM
    #51
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    A buddy of mine has this problem also, so I tried to get into his truck...no way....My legs are too long and I could not even get into his truck...had to move the seat back, then re-adjust...
    For you short legged guys...try to get in the habit of sliding the seat back on exit and you will have no problem entering next time... A pain, I know, but this is how my buddy does it and has got so used to doing it, he does not even notice it anymore...
  12. Nov 12, 2016 at 5:29 PM
    #52
    rz2mbc
    rz2mbc Well-Known Member
    4 wheel disc brakes with ant-lock.
    Good motor with more guts.
    Be able to order options and not a package !
    Give the "Limited" more options and make it a true Limited...i. e. ,cooled seats, more electronics, folding mirrors, etc
  13. Nov 12, 2016 at 5:33 PM
    #53
    JoeyDel
    JoeyDel Well-Known Member
    Joe
    South Jersey
    2003 Off Road AC and '16 AC Sport Silver Sky Metallic
    I miss the 14 or so cup holders that were in my 2014 Sport.
  14. Nov 12, 2016 at 5:35 PM
    #54
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    This... and offer it with a manual transmission.
  15. Nov 12, 2016 at 5:47 PM
    #55
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    All new sheet metal with new A-B pillars true redesign.Access cab get new side windows that go below door windows think 80's.Smaller first gen size.
  16. Nov 12, 2016 at 5:59 PM
    #56
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    more adjustments for tilt and telescopic steering
  17. Nov 12, 2016 at 6:07 PM
    #57
    over60
    Muskoka, Ontario
    Why do you miss the 1 cup holder?.. I've got 13.. I can't even drink that much coffee/beer/water in a day...???
  18. Nov 12, 2016 at 6:29 PM
    #58
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Id say make that new hood lighter. Shew my buddy leased one and we looked under the and dang if it doesnt weigh a crapload man.
  19. Nov 12, 2016 at 6:30 PM
    #59
    jsi
    jsi Well-Known Member
    native earthling
    This ^ just make this again. Each generation of Tacoma keeps getting bigger, fatter and more complex. Just make the 1985 truck up to modern standards and I'd buy one in a second.
    Short of Toyota building this dream truck the chance of me buying a new Tacoma is exactly zero. (not bashing 3rd gens, just saying smaller, simpler, cheaper are really attractive to me.)
    Spare Parts likes this.
  20. Nov 12, 2016 at 6:39 PM
    #60
    over60
    Muskoka, Ontario
    My Dog..!! Your Taco lasted 31 yrs and looks like that..?? Must be no salt in your State..!! hehe
    Nice truck man..:thumbsup::canada::canada:
