[CLOSED] Tacoma Retrofit Headlights Group Buy (Spring 2017)
Discussion in 'Automotive Group Buys' started by LSC15, May 10, 2017.
  1. May 10, 2017 at 7:19 AM
    LSC15
    LSC15 [OP] Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    THE LSC15 RETROFIT GROUP BUY
    My Passion is to supply fellow TW Members with Quality Lighting
    [ STARTS MAY 10TH TIL MAY 31ST ]
    This season's group buy offers members a discount off my current pricing and free shipping!!!
    HOW TO ORDER
    Contact me with any questions regarding your exact order specs (what options you want)
    Once your specific retrofit option's are decided, I will need the following.
    Please copy and paste this list into your message when you order and fill it out.
    · Full Name –
    · Vehicle Year –
    · Stage # w/ Additional Options –
    · Phone Number -
    · Shipping Address -
    Once options are finalized a final quote will be given and payments can be made through PayPal to logancarlton15@gmail.com as a gift or for goods and services if buyer covers associated fees.
    I build the lights (in the order you're on the list which is based off when order was placed) and then ship them when finished.
    Wait times will vary depending where you are at on the list. The higher up you are on the list then the quicker you will receive your lights. So order Fast!!
    Order List
    1. @Hummer911 - SHIPPED
    2. @mm3tacoma - SHIPPED
    3. @boogie3478 - SHIPPED
    4. @CountryTaco - SHIPPED
    5. @mbreckner - SHIPPED
    6. @Link6 - SHIPPED
    7. @Braunschwaga - SHIPPED
    8. @Jperez - SHIPPED
    9. @nzbrock - SHIPPED
    10. @Syphrum - SHIPPED
    We only use Parts from
    Toyota / The Retrofit Source / Diode Dynamics / Led Concepts / TYC
    To upgrade from aftermarket housings to OEM Toyota housings contact me to discuss! ***I HIGHLY RECOMMEND OEM OVER AFTERMARKET HOUSINGS (Better Quality)***
    Have your own OEM Headlights you want to use for build or core return?
    Contact me directly as we can work out the details
    Link to retrofitting page to view some of my work!
    https://www.tacomaworld.com/threads/retrofitting-services-for-all-tacomas.342693/
    [ 2012-2015 STAGE I $825 SHIPPED ]
    - Brand New Aftermarket Housings
    - Brand New H1 7.0 Projectors
    - Shroud Design of your Choice / Check The Retrofit Source's website @ (http://www.theretrofitsource.com/components/shrouds.html )
    - Chrome Factory Color Scheme
    or
    - Blacked Out Paint Work ( BEZEL / BOWL / SHROUD / DTRL BLINKERS )
    - You can request to leave certain parts of the headlight chrome
    - Brand New 35W Morimoto ballasts
    - Brand New XB35 Morimoto Bulbs (4500k, 5500k, or 6500k)
    - Brand New Morimoto H4 Wiring Harness​
    [ 2012-2015 STAGE II $875 SHIPPED ]
    - Brand New D2S 4.0 Projectors
    or
    [ 2005-2011 STAGE I $700 SHIPPED ]
    - Shroud Design of your Choice / Check The Retrofit Source's website@ (http://www.theretrofitsource.com/components/shrouds.html )
    or
    [ 2005-2011 STAGE II $750 SHIPPED ]
    or
    [ 1995-2004 STAGE I $575 SHIPPED ]
    or
    - Blacked Out Paint Work ( BOWL / SHROUD )
    [ 1995-2004 STAGE II $650 SHIPPED ]
    or
    [ ADDITIONAL OPTIONS FOR ALL STAGES ]
    - LED Demon Eye / Lights up inside the projector lens. (Color of your choice - Red, Blue, Green, Amber, or Purple) +$100
    Switchback Halos (Front or Rear mounted) +$125 For One Set / +$225 For Both Front & Rear
    - RGB Color Changing Halos (Front or Rear mounted) +$175 For One Set / +$300 For Both Front & Rear
    - RGB Color Changing LED Demon Eye +$150
    - Clear / Light Clear Smoke / Dark Clear Smoke Replacement Reflectors +$75
    Custom Color Matched Paint +$75
    - Custom Art/Design Etching in Projector Lens +$100
    - OEM Upgraded Bulbs are Available for D2S Projectors (Pricing Varies)
    - Hydro-dip Patterns (Pricing Varies)
    - 55W Ballasts instead of 35W +$10
    - HAWAII / ALASKA Shipping +$50
    FAQ
    Q. Is there a warranty?
    A. Yes. We offer a one year warranty on workmanship. TRS components follow the TRS warranty period. For info on warranty for specific parts, review TRS website or contact me directly. All warranty claims will come through me and I will handle it for you. No hassle warranty.
    The cost of shipping the headlight(s) to to me is the original owner's responsibility. I will be responsible for the cost of returning the warrantied headlight(s) to the original owner within the U.S. Sorry, if you are outside the U.S., you pay shipping both ways. This warranty is NOT transferrable. Any modifications and/or tampering of headlights will void the warranty.
    Q. How hard is it to install the headlights and wire harness once I receive them?
    A. If you have a slight bit of mechanical skills, then the installation will not be difficult. The wire harness is plug 'n play, no splicing of the OEM harness is required. The new, retrofitted headlight bolts up the same way your old one was removed. Wire harness instructions are included with your shipped headlights as well as online.
    http://www.theretrofitsource.com/pdf/trs_tech/Bi-Xenon MotoControl Relay Harness.pdf
    The OEM headlight aiming mechanism remains fully functional. After your retrofitted headlights are installed, some fine tuning will be required utilizing the OEM adjusters. Fine tuning is defined as matching both the left and right cut-off so that they are level with each other. As a rule of thumb, I recommend aligning the height of the cut-off to be horizontal with the upper trunk line of the average sedan.
    Q. Where can I learn more about retrofitting, projectors and HID bulbs?
    A. The Retrofit Source (TRS) has a tremendous amount of online material to enhance your retrofitting knowledge.
    http://www.theretrofitsource.com/trs_tech.php
    Q. What's the difference between the bulb colors?
    A. Kelvin Ratings: 3000K - Has a golden yellow output perfect for use in fog lights. The yellow light penetrates through snow, rain, and fog more effectively than white or blue light. 4500K - Has a slightly off-white output similar to that of sunlight. Most cars that come equipped with HID headlights from the factory use 4500K bulbs. If you want the most usable light, 4500K is the Kelvin rating for you. 5500K - A pure white output, no tinge of yellow, and no tinge of blue. 6500K - A white light with a little tinge of blue. As you move into the higher kelvin ratings, your light output will appear more bluish-purple in hue, but the bulbs won't be physically as bright. As HID bulbs age, they go through what is known as "color-shift". When the bulbs are brand new, the output is whitish-yellow and as physically bright as it will ever be. As the bulbs age with use, their output turns more pure white/bluish and also starts to dim a bit. That's why cars with factory 4300K bulbs that are 5+ years old look like they're running 5000K or higher bulbs.
      File size:
      67.1 KB
      5,106
      File size:
      57.7 KB
      5,078
      File size:
      102.6 KB
      5,171
      File size:
      43.7 KB
      5,124
      File size:
      77.7 KB
      4,752
      File size:
      6.6 KB
      5,025
      File size:
      81.1 KB
      4,904
      File size:
      117.6 KB
      5,210
      File size:
      115.2 KB
      2,059
      File size:
      99.4 KB
      2,040
      File size:
      99.2 KB
      2,116
      File size:
      94.1 KB
      2,090
      File size:
      110.9 KB
      2,096
      File size:
      99.5 KB
      1,728
      File size:
      70.8 KB
      1,676
  2. May 10, 2017 at 7:43 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    So much wants​
    syswalla, jamiec, kyuss88 and 3 others like this.
  3. May 10, 2017 at 8:06 AM
    philmdnls
    philmdnls Well-Known Member
    Philip
    NC
    2004 Black Double Cab 4x4
    You quoted me $750 for mini H1´s, mini Gatling Guns, blacked out, and color changing Halos. Would it be cheaper in this group buy?
    ChadsPride likes this.
  4. May 10, 2017 at 8:46 AM
    LSC15
    Logan
    2008 TRD D-Cab
    Put that order in
    It's $750 shipped now. Price went up on halos due to new Bluetooth design
    scottalot and ChadsPride[QUOTED] like this.
  5. May 10, 2017 at 8:48 AM
    philmdnls
    Philip
    NC
    Okay cool. I'll definitely be placing an order if I can get my dad on board.
    RIDERED67, scottalot and ChadsPride like this.
  6. May 10, 2017 at 8:53 AM
    LSC15
    Logan
    2008 TRD D-Cab
    Do it buddy!
  7. May 10, 2017 at 8:57 AM
    LocoLocal
    LocoLocal Aspiring Polymath
    39.081221472127545, -77.45538862919935
    Large American
    Brah, you and me both.
  8. May 10, 2017 at 8:59 AM
    LSC15
    Logan
    2008 TRD D-Cab
    Jump on this group buy guys
  9. May 10, 2017 at 9:52 AM
    philmdnls
    Philip
    NC
    The convincing is underway. So if I chose to upgrade to OEM housings, how much would that raise the price?
  10. May 10, 2017 at 9:54 AM
    LSC15
    Logan
    2008 TRD D-Cab
    OEM housings don't make a huge difference on 1st gens. Really recommended for second gens
  11. May 10, 2017 at 9:55 AM
    philmdnls
    Philip
    NC
    Okay sweet. So it's safe to stick to aftermarkets, or should I just go ahead and move up to OEM?
  12. May 10, 2017 at 9:59 AM
    LSC15
    Logan
    2008 TRD D-Cab
    For an 04 model, the tyc aftermarkets are great and what I will use
  13. May 10, 2017 at 10:00 AM
    philmdnls
    Philip
    NC
    Okay, sounds good. I'll see if I can get any closer to getting my dad on my side.
  14. May 10, 2017 at 10:01 AM
    LSC15
    Logan
    2008 TRD D-Cab
    Alright buddy let me know
  15. May 10, 2017 at 10:05 AM
    LSC15
    Logan
    2008 TRD D-Cab
    @ChadsPride you liking all the posts but not posting or ordering. You know you want to!!
  16. May 10, 2017 at 10:05 AM
    ChadsPride
    I just got my like button back lmao
  17. May 10, 2017 at 10:13 AM
    LSC15
    Logan
    2008 TRD D-Cab
    I hear ya boss
  18. May 10, 2017 at 10:31 AM
    philmdnls
    Philip
    NC
    So if I kept everything the same and just switched the color changing halos to white only, how would that affect the price? Thank you for answering all of my questions.
  19. May 10, 2017 at 10:33 AM
    Darklight
    Darklight Well-Known Member
    Bobby
    Charlotte,NC
    2008 Black SR5 V6 4Runner
    http://www.toyota120.com/forum/showthread.php?t=26920
    Make some for a 4th gen 4Runner, those are sweet!
  20. May 10, 2017 at 10:40 AM
    LSC15
    Logan
    2008 TRD D-Cab
    I can do any vehicle. I'll include 4runners and Tundras on this GB
