Tacoma Riddle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shanman, Mar 27, 2017.
  1. Mar 27, 2017 at 6:39 PM
    shanman
    shanman [OP] Member
    2006 Tacoma TRD
    I hum faster or slower according to your speed. I've grown stronger over the last few months. Now you can feel my slight vibration in your hands and feet. My weirdest quirk is that I love to put on my show when youre driving straight or turning left, but I quit my performance when you turn right.
    What am I ? Be specific.
    Bocsy44 likes this.
  2. Mar 27, 2017 at 6:40 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
  3. Mar 27, 2017 at 6:42 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Possible right front wheel bearing.
    Welcome to TW!
  4. Mar 27, 2017 at 6:45 PM
    shanman
    shanman [OP] Member
    2006 Tacoma TRD
    I was thinking front wheel bearing, but it's hard to tell which side its coming from. So you think its most likely the right side then?
  5. Mar 27, 2017 at 6:48 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Wheel bearing failure is most audible when the wheel is under load. Turning toward the failing bearing transfers the weight to the other side of the vehicle, quieting the bearing. Turning away from the failing bearing transfers weight onto the failing bearing causing it to become more audible. (Think how a vehicle leans when you turn).
  6. Mar 27, 2017 at 6:56 PM
    shanman
    shanman [OP] Member
    2006 Tacoma TRD
    Makes sense. Awesome! I'll try to replace it this weekend. thanks for the help!
  7. Mar 27, 2017 at 7:02 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    See if one hub feels a little warmer than the other after you drive it for a while. Avoid braking hard before you stop before you check it. If you have an infrared pyrometer, check different places from one side to the other. If you have a bearing going out, it might be a little warmer??
  8. Mar 27, 2017 at 7:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Typical bearing failure makes an unsteady wahwahwahwah kinda noise.
  9. Mar 27, 2017 at 7:04 PM
    winkel
    Corydon, IN
    Also, check the play in your axle shafts where they come out of the front diff. Just wiggle them by hand and see if one side is looser than the other. You might find the driver sided is considerably looser than the passenger.
  10. Mar 27, 2017 at 7:05 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    The advise I got when I had a front wheel bearing failing was to jack up the front and spin the wheels by hand the one that sounds like it has sand in it is the one to replace
  11. Mar 27, 2017 at 7:13 PM
    NiteTaco
    NiteTaco Well-Known Member
    North Alabama
    09 TRD DCSB
    Sounds like mine which needs to have the front diff needle bearing replaced with the ECGS bushing sitting in the box...Just haven't had time yet. See if there's play/wobbling when you shake the driver side CV axle where it goes into the diff...If it feels loose and sloppy, then needle bearing replacement time.
  12. Mar 28, 2017 at 12:47 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If mine were a 2006 and one front bearing is worn I would go ahead and replace them both, the other side will not be far behind.
    lowrange likes this.
  13. Mar 28, 2017 at 1:49 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    I agree you change two headlight bulbs.You have all the tools dont b a fool change both bearings And roll on!!
