Tacoma Roof Rack Installation Tip
Discussion in 'Technical Chat' started by Troofrack, Jun 29, 2018.
  1. Jun 29, 2018 at 7:55 PM
    Troofrack
    Troofrack [OP] New Member
    Al
    2018 Tacoma SR5
    Roof Rack
    I just bought and installed a rack for my 2018 Tacoma. It adds a lot to the looks of the truck but it's only rated for 100 pounds.
    It was easy to install up to the last bolt that holds the swing arm on the (right) passenger side.
    There is a keeper nut that is snapped into the underside of the rack that pushes out when you try to thread the last long bolt into it - then it's too late. The keeper nut should be molded into the plastic. The rack is attached to the metal base bracket with a press fit (yellow) fitting and you can no longer retreive and snap in the keeper nut so it doesn't push out. This is a bad design flaw.
    Make sure that the first thing you do when you take the rack out of the box is to put some glue around that keeper nut so it will stay in place unbtil you install the rail and thread the last bolt into it.
    I ended up stripping the bolts after several install/remove attempts.
    When I tried ordering a new bag of bolts I found that the part number on the bag was not available.
    Make sure that keeper nut can't push out and the rest of the installation is easy.
  2. Jun 30, 2018 at 11:34 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Welcome! What brand rack? :worthless:
