Tacoma SAS Part Two: The Swap
Discussion in 'Solid Axle Suspension' started by tacoma02, Apr 11, 2016.
  1. Apr 11, 2016 at 7:06 PM
    tacoma02
    tacoma02 [OP] Well-Known Member
    2002 Toyota Tacoma 2.7L 4 Cylinder
    Thrush Welded Muffler Westin safari light bar
    The SAS is done! For now...
    This thread won't be nearly as detailed as the axle rebuild. Sorry.
    My buddies and I were able to complete the job in two weekends. It was a lot of work and I didn't get as many pictures as I would have liked.
    Here it goes...
    We got the truck out of Grandmas garage and onto the trailer.
    Brought it over to my buddies shop where he's got a lift. Not that we didn't like grandmas. The shop just has a little more room and we didnt have to worry about throwing anymore sparks on her Oldsmobile.
    Saying goodbye to the IFS.
    You will need a torch or a plasma cutter for this. The torch seem to work the best. After that we were in for a whole lot of grinding!
    Gone
    THROTTLE231 likes this.
  2. Apr 11, 2016 at 7:16 PM
    tacoma02
    After about a full evening of grinding, we got the frame rails cleaned up enough to attach the Trailer Gear reinforcement plates.
    All welded up.
    Also welded on the front cross member and spring hangers.
  3. Apr 11, 2016 at 7:18 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    where is part 1?
  4. Apr 11, 2016 at 7:24 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Looks sic! Subbed
  5. Apr 11, 2016 at 7:28 PM
    tacoma02
    We mounted the springs to the axle and bolted them up to the front hangers. This allowed us to figure out where the rear shackles needed to be mounted.
    I would recommend tacking the rear shackle mounts in place before fully welding them. You will need to put some weight on the springs to see what the shackle angle looks like.
    It took us a while to get it right. A lot of cutting and re-welding.
    Triple checking that everything is straight.
    Couldn't wait to put the tires on.
  6. Apr 11, 2016 at 7:34 PM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    Subd. Can you post a link to your axle build thread?
  7. Apr 11, 2016 at 7:40 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Found it -> HERE
    tdnick likes this.
  8. Apr 11, 2016 at 7:42 PM
    tacoma02
    Had to modify the transmission crossmember to clear the new front drive shaft.
    Remember to secure the transmission before removing the crossmember!
    Welding on the shock mounts.
    Ready to rock n roll.
    Didn't take long to get it dirty.
    sawjai526, Pirhett and THROTTLE231 like this.
  9. Apr 11, 2016 at 7:44 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You made that look easy!
  10. Apr 11, 2016 at 7:51 PM
    tacoma02
    Again, sorry this writeup wasn't as detailed as the last. There was just to much going on during the swap to stop and take pictures.
    What you would really need to follow are the trail gear intructions. Link below...
    https://www.google.com/url?url=http...QmhohA&usg=AFQjCNFC9rEJLYkmDF_XyJX7UyCWyBI6Xg
    There were alot of other things that I do not have pictured. The trailer gear intructions do a great job covering that.
    When I have some time I can upload some more photos of underneath the truck.
  11. Apr 11, 2016 at 8:21 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Wow that's tall. Whats up with the rubber under the grill? 2 weekends, nice! I've been dicking around with frame plates for a month LOL
  12. Apr 13, 2016 at 4:15 AM
    Poofyfoot
    Poofyfoot Well-Known Member
    Jordan
    Logan, Ohio
    89' Pickup and 2013 AC Sport
    Nicely done! :popcorn:
  13. Apr 13, 2016 at 4:18 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Damnit... y'all are quick.
    What is the frame height as it looks tall.
  14. Apr 15, 2016 at 11:03 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    Wow that looks tall... Nice and quick. Hoping I can do the same without a lift!
  15. Apr 21, 2016 at 8:16 PM
    ekahi1
    ekahi1 CUZ I CAN
    Hilo Hawaii
    97 xcab sas baja front
    Dana 44 SAS,locker,4:88s,6" lift,16x10 weld mountain crushers, fox shocks.
    what size tire and front lift are you running?
  16. Apr 21, 2016 at 8:24 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    I like it. Looks good! :thumbsup:
  17. Apr 23, 2016 at 1:41 PM
    1999RegCab
    1999RegCab Well-Known Member
    Cacti Land, AZ
    1999 Reg Cab, 2.7, 5 speed
    3-link SAS
    Very clean build. Looks good.
    X4 on being tall. I guess that's the nature of the beast when doing a SAS with leaf springs...until they begin to settle or you start modifying the the leaf packs - whichever comes first.
    Also...you gonna hate those swamper TSL radials :D
  18. Dec 8, 2023 at 5:16 AM
    Tikibutt
    Tikibutt Well-Known Member
    Rich
    Knoxville, TN
    2004 Tacoma 4x4
    JBA UCAs, Radflo Coilovers, Lockrite mechanical Locker, All-Pro Offroad Skid Plates, 4x Innovations Sliders, Dakar Rear Springs, 37x13.50r17 Cooper SST Pro on Beadlocks
    Getting ready to do the same swap on my 04. Did you swap the oil pan? Looking at pics, I think you did. Did you move the dipstick?
    Yetimetchkangmi likes this.
