Tacoma sat for 3-4 weeks and battery won't start engine. Normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimLS, Jan 11, 2025.
  1. Jan 11, 2025 at 3:27 PM
    JimLS
    JimLS [OP] Well-Known Member
    My 2023 V6 Tacoma has been sitting in my garage for about 3.5 weeks. About 55F in there now. I went to start it and just got some clicking. It's not totally dead but it needs charging or a jump to start. Is there enough "vampire" drain with everything off that this is to be expected? Or might the battery be bad? I have only had it for a year as I bought it just after Jan 1, 2024. Seems crazy for it to not even last 4 weeks.
  2. Jan 11, 2025 at 3:29 PM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Yes. That’s normal for most any car.
    Phlogiston and Chew like this.
  3. Jan 11, 2025 at 3:33 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Put a charger on the battery and see how it performs. Keep an eye on your warranty expiration date. My battery developed a bad cell at 33 months into my warranty and Toyota gave me a free new TrueStart battery.
  4. Jan 11, 2025 at 3:40 PM
    PoorWhiteBoi
    PoorWhiteBoi Active Member
    2022 SR5
    My 2022 sr5 with original battery sat for 32 days this past October-November and fired right up when I returned home. Sat outside in the Florida weather.
    shakerhood likes this.
  5. Jan 11, 2025 at 3:41 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Get a NOCO GB40 battery boost for such occasions. If it sits unused for weeks, keep it on a trickle-charger ... I think NOCO sells those.
    But once a lead-acid battery has been dead, its life is already shortened. I would start budgeting for a new battery if warranty refuses to pay.
    Chew likes this.
  6. Jan 11, 2025 at 4:44 PM
    InThePlains
    InThePlains Well-Known Member
    Not sure if it's normal or not. I've had mine sat for 7 weeks at work and started right up after.
    You may check for parasitic draw.
    Canadian Caber likes this.
  7. Jan 11, 2025 at 4:59 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I just went through this nearly same scenario. Just last week, I hadn't started my 2019 with a one year old battery for almost 4 weeks and it cranked noticeably slow. Come Spring, I need to put an outdoor outlet on my house and keep it on a battery maintainer. Letting batteries discharge this low is not good on them. My GF's parents had the same issue with their 2.5 year old Honda CRV that sits in the garage undriven for several weeks at a time. I put a battery maintainer on it, and no more problems.
    t0p_d0g, Canadian Caber and Jakerou like this.
  8. Jan 11, 2025 at 5:13 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Could happen. Remember, the Battery is not Toyota built!
    Fireball 00 likes this.
  9. Jan 11, 2025 at 6:50 PM
    18trdsport
    18trdsport Well-Known Member
    Bay Area, CA
    2018 TRD Sport ACLB MT
  10. Jan 11, 2025 at 7:59 PM
    JimLS
    I don't have anything like that on the OBDII port. The battery measured 11.5 V before I started charging it - that shouldn't cause any damage. I will keep an eye on it. Not sure what sort of warranty the battery has. Is that covered under the 2 years?
  11. Jan 12, 2025 at 4:44 AM
    JimLS
    did some measurements...
    Load with everything off is 52 mA. Seems like a lot. Would be interesting to know what the major loads are.
    Putting a 2.5A charger on it raises the voltage 0.9V immediately. Pretty good indication the battery is bad - high internal resistance. I am going to charge it and see if that helps but I doubt it. I am due for service so will ask for a new one when it goes into the dealer.
    I looked up a replacement battery. Had a 70Ah rating. At 52 mA it should take 56 days to add up to 70Ah and that isn't total discharge - not sure what the minimum is but guessing it will be down to 10 or 11 volts. That's about twice as long as this sat.
    tacofish likes this.
  12. Jan 12, 2025 at 11:08 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    No not normal. I have left my truck sitting 3 months and the boat 6 months. Both started right up. But it can happen.
  13. Jan 12, 2025 at 11:14 AM
    Bishop84
    Bishop84 Well-Known Member
    It's considered normal. Batteries exist in different states of charge and health but most manufacturers can only ensure 2 weeks of drain.
    A battery tender is a must if you leave the vehicle like this on routine. If its just vacation, simply disconnect the battery next time.
    Chew likes this.
  14. Jan 12, 2025 at 11:20 AM
    gudujarlson
    Minnesota
    I left the boat all winter 6+ times for 6 months with no battery tender and never had a problem. I think that’s par for the course in Minnesota for boats. The cold winter might extend the battery charge.
    Many people do recommend a battery tender and it doesn’t seem like a bad idea.
  15. Jan 12, 2025 at 11:32 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Modern autos talk to the mothership, onstar, xm, etc... Plus the keyless fobs in "standby" and are constantly searching for signal, reporting. Just driving them daily isnt enough, you should put the truck on a tender to full, every 6-8 weeks, to prolong battery life, and not have what happened to you. Ski
    Fireball 00 and Chew like this.
  16. Jan 12, 2025 at 11:33 AM
    JimLS
    Charged it at 3-4A for about 5 hours. Voltage when charging was 13.3V. Charger removed was 12.8V. It started right up from just the battery. Took it for about a 15 minute drive. Voltage with engine running at the end was 13.8V. Engine off was 12.5V. It's not what I would expect from a 18month old battery but not completely shot either. Will see if it starts in the morning but I'm guessing it will.
    I see there is a fuse box jumper labeled "short". My understanding is that disconnects the vampire loads for when the truck is shipped from the factory. I could pull that for extended non-use but it looks like that disconnects the radio and other things that would need to reprogrammed with favorite stations and maybe other stuff which would be a hassle.
  17. Jan 12, 2025 at 11:38 AM
    JimLS
    I get most of that. But the "driving them daily isn't enough" makes no sense. Why would I need to put it on a tender every couple months if I am driving it every day or nearly every day? That sounds bogus...
  18. Jan 12, 2025 at 12:46 PM
    Bishop84
    Pulling the short fuse is a good idea, it reduces the draw. Personally I'd still suggest just disconnecting the battery, it ensures zero drain.
    A discharged battery isn't good and it shortens the life, especially in cold regions.
    Chew likes this.
  19. Jan 12, 2025 at 6:32 PM
    skidooboy
    central lower mich
    If you dont drive it far enough to get a full charge, it doesnt work like putting it on a tender to get to full charge. Dont believe me, check the charging amps on your alternator, then find a tender with close to the same amp charging capacity, time how long it takes to charge the battery full. If it takes hours to charge full, and you dont drive hours daily... It isnt getting a full charge. You should "top it off" every 6-8 weeks with a tender, to add longevity to your battery. Not bogus at all. Ski
    Chew and t0p_d0g like this.
  20. Jan 12, 2025 at 8:27 PM
    JimLS
    Ok. I suppose if I only went a block every time I drove that might be a thing. But virtually no one does that. If they only drive 15 minutes to the store and 15 minutes back I think that will charge the battery enough to keep it up and also likely some trips are a bit longer too. If it wasn't enough to charge the battery to replace what was lost starting they would need to charge it sooner than 6-8 weeks. I still say bogus. I have been driving for 50 years and never needed to top off a vehicle that was used with any regularity.
    And the charging amps on a tender is low. Not anywhere close to the output of an alternator. That's why it takes hours to charge a battery on a tender - it's a very low charge current.
