Tacoma sat for 4-5 years
Discussion in 'Technical Chat' started by RDenn15, Jun 5, 2018.
  1. Jun 5, 2018 at 4:12 PM
    RDenn15
    RDenn15 [OP] Member
    1999 Tacoma 4x4
    New member here.
    My Mom let her 1999 Tacoma sit for 4-5 years without starting it. I had no idea she wasn't running the truck. It has 204,000 miles on it.
    I was wanting to buy it from her and now I'm not sure if it's ruined. Worst case scenario, what all would have to be replaced on the truck? Is it even worth messing with?
    Thanks
  2. Jun 6, 2018 at 12:45 PM
    RDenn15
    RDenn15 [OP] Member
    1999 Tacoma 4x4
    I appreciate your response. I'm getting so many different opinions. One mechanic told me the truck was ruined.
    wilcam47 likes this.
  3. Jun 6, 2018 at 12:49 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Drain the gas/fuel system. Hope the gas has not turned to jelly.
  4. Jun 6, 2018 at 12:49 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Id check the fluids , jump the battery and let it run. After it ran change all fluids and go over the whole truck.
    Jcyr and Crow_of_judgement like this.
  5. Jun 6, 2018 at 12:50 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Definitely not ruined... is it a 4cylinder or 6?
    Siphone the tank fill with fresh gas and some star tron to get any other moisture out. Check radiotor fluid as well then new battery and start her up. If she starts I’d do an oil change immediately like that day not next week. The only thing that really goes back is rubber components.. gaskets seals/belts. If it’s a 4cyl you have a timing chain not a timing belt so you’re good their if she ain’t leaking ride her hard
    mackb likes this.
  6. Jun 6, 2018 at 12:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    Its ruined. PM me the address and I'll come drag it off for her. :thumbsup:
  7. Jun 6, 2018 at 12:57 PM
    Mateo74
    Mateo74 Well-Known Member
    Matthew
    NWI
    16' Tacoma Sr5 Blazing blue pearl
    I have no doubts that it will start, but personally I would pull the plugs and put some oil in each cylinder and let it sit overnight. Meanwhile checking air box for a nest and Siphoning out old gas with new using an additive for moisture.
    WSW3 likes this.
  8. Jun 6, 2018 at 1:02 PM
    RDenn15
    RDenn15 [OP] Member
    1999 Tacoma 4x4
    I'll try to answer everyone's questions.
    She stopped driving it because she has another an 05 tacoma and the steering went out on the 99.
    The 99 is a 6 cylinder. It's located in DFW.
    I was hoping I could drain the gas, change all fluids, replace the battery, fix the steering issue, and then have a good little truck.
    wilcam47 and synaps3 like this.
  9. Jun 7, 2018 at 9:58 AM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
    Steering out probably means power steering. You can still drive it with power steering out.
    I think you covered it well -- drain all fluids (gas, coolant, oil, tranny, tcase, diff) and refill, change battery, and drive it.
  10. Jun 11, 2018 at 6:06 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Only if it was in a flood...if its just been sitting doubtful and would be a good truck.
    sounds like you got a handle on it...check for mice/rat nest in the engine and if they chewed on wires etc.
    with new gas, oil and battery it should fire right up IMO. also change the fuel filter.
  11. Jun 11, 2018 at 6:08 PM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Drain the fuel and put some fresh fuel in. Clean the efi too. Fire it up. I’d also do an oil change ASAP but make sure it runs first
  12. Jun 11, 2018 at 6:11 PM
    wilcam47
    Will
    Bourbon state
    It might be a rough start till the fresh fuel gets through the lines...
