Tacoma sat in Isaias water. Any issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreidasBoss, Aug 4, 2020.
  1. Aug 4, 2020 at 8:26 PM
    FreidasBoss
    FreidasBoss [OP] Well-Known Member
    PA
    2020 TRD Sport 4x4 DCLB
    Isaias hit my area pretty good today. While down the basement pumping out water my wife tells me that the water is getting up the sides of the truck. Ran out and moved it to higher ground.
    I might be overthinking it, but are there any concerns with it sitting in water up to just below the body? Couldn’t have been in there for more than 10 minutes. Didn’t seem like there were any issues driving it.
    It’s barely a month old and I’m not looking to trash it just yet. Just covering my bases. Thanks.
    davidstacoma likes this.
  2. Aug 4, 2020 at 8:28 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Should be fine unless water got into the intake but at that level I doubt it. Sucks, man glad you are okay, hopefully the basement too ;)
  3. Aug 4, 2020 at 8:30 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Drive it around the block and check all the fluids for water contamination
  4. Aug 4, 2020 at 8:37 PM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    I'm not being sarcastic but once you get a chance, let the thing dry out, test for water contamination in the fluids, drive it around, let it sit, then do it all again.
    02Duck likes this.
  5. Aug 4, 2020 at 8:38 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    You should be fine if that's as high as it got.
    CusterFan, synaps3, Ch78 and 3 others like this.
  6. Aug 4, 2020 at 8:44 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Rear diff vent was likely under water. 100% stock they are not good for very much water.
  7. Aug 4, 2020 at 8:44 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    It will be fine, water level doesn't seem high enough to hurt anything considering the short time.
  8. Aug 4, 2020 at 8:46 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Check your fluids when its dry, if it was me, i'd likely be draining and refilling the rear diff fluid
    CusterFan, tonered, DAS Taco and 3 others like this.
  9. Aug 4, 2020 at 8:50 PM
    FreidasBoss
    PA
    Yeah, it’s stock. I’ll have to check the diff, that was my main concern. Thanks.
    CusterFan, tonered and TacoBuffet like this.
  10. Aug 4, 2020 at 8:52 PM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    If the water level didn't get any higher, you should be ok..
    CusterFan likes this.
  11. Aug 4, 2020 at 8:53 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    It's totaled. Consider it a flooded vehicle, with electrical gremlins and rust throughout the rest of its life.
    Best to sell it to Carvana, get most of your money back, and purchase a new Tacoma.
  12. Aug 4, 2020 at 8:57 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Please know what you are talking about before you type. It was cold so there is zero problem with water ingestion into diff.
    OP, only issue is water in bearings. You should be fine.
  13. Aug 4, 2020 at 8:58 PM
    TacoBuffet
    AL
    I was biting my tongue, lol.
  14. Aug 4, 2020 at 9:02 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Trucks fine. Post pictures of your basement flooding. Curious to see how you’re handling that. Goodluck
    TRD4X4TOY and TacoBuffet like this.
  15. Aug 4, 2020 at 9:13 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Looks like your fuel pump controller was submerged as it’s mounted on the inside of the frame rail between the transfer case and gas tank.
  16. Aug 4, 2020 at 9:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd at least check the differentials
    whatstcp and CusterFan like this.
  17. Aug 4, 2020 at 9:28 PM
    Bayou Bengal
    Bayou Bengal Member
    Andrew
    Southeast Louisiana
    If the engine starts I'd say it's fine, if that's as high as it got. Can always open an insurance claim and see what they say - might get a new truck out of it
  18. Aug 4, 2020 at 9:50 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Why. It was cold. No water ingestion because of heat. This is off road 101, not masters 400 level.
  19. Aug 4, 2020 at 9:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    OP, my rule is top of tires cold. If you keep it below top of tires and the diffs are cold, no worries. If diffs are hot and up to axle, drain diffs and refill asap.
  20. Aug 4, 2020 at 9:56 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Let the dealer look at it , insurance should cover if they find something .
    There was a poster on here that his actuator took on water and they said he was in to deep of water . Warranty wouldn't cover it and it was pricey .
    Lt. Dangle likes this.
