Tacoma sat in Isaias water. Any issues?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreidasBoss, Aug 4, 2020.
  1. Aug 5, 2020 at 6:59 AM
    #41
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Laugh, but read other threads on flooded vehicles, and see what problems they have.
    Things like:
    will not slip in/out of 4WD with warning lights due to actuator damage or transfer case water intrusion
    stalling due to fuel pump electonics failure
    contaminated gas due to water intrusion
    brake malfunctions and ABS warning lights
    whining differentials due to water intrusion
    transmission problems due to water intrusion
    accelerated frame rust and fastener corrosion
    no taillights and other malfunctions due to wire harness water damage
    bearing damage from water intrusion
    and so on ...
    The OP will take it to the dealership, and the vehicle will be reported as flooded and warranty repairs will be in question.
    Or, the OP waits until problems occur, takes it to dealership, and flooding remnants will be determined and warranty questioned.
    Quite a gamble on a $40K purchase.
    As I say, laugh!
    Bleep100 likes this.
  2. Aug 5, 2020 at 7:06 AM
    #42
    Kaptain_02
    Kaptain_02 2019 OR
    Yeah, but isn’t a case of a ‘flooded vehicle’ for the OP.
  3. Aug 5, 2020 at 8:47 AM
    #43
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Where does he say it was cold? He said his wife informed him the water was rising quick? Maybe he just came home from work. The water is nearly to the top of the rims, so over the difference. The guy asked for possible issues.
  4. Aug 5, 2020 at 9:09 AM
    #44
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    With the lake now so low now i couldn't even load my boat on the trailer to put it in the garage. This rain helped a little, but still the boulders are showing above the water around where my boat is docked that normally are under water a few feet. At any rate the boat survived the storm no worse for wear...just needs some cleaning up.
  5. Aug 5, 2020 at 9:16 AM
    #45
    Sungod
    Sungod Well-Known Member
    St Augustine
    Is that as deep as the water got? If so, just dry your wheels off with a micro fiber towel and worry about more pressing issues like what kind of lift you are getting.
    44-16 Taco, davidstacoma and whatstcp like this.
  6. Aug 5, 2020 at 9:38 AM
    #46
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Reading comprehension..."While down the basement pumping out water my wife tells me that the water is getting up the sides of the truck. Ran out and moved it to higher ground."
    Plus, the water is not even to the breather.
  7. Aug 5, 2020 at 10:45 AM
    #47
    DanoTay
    DanoTay Well-Known Member
    Victoria, B.C.
    2019 Tacoma OR AC MT
    If it was me, I would just drive the truck and call it an deep water off road adventure. However if the OP needs some sort of piece of mind, and since any problems would not be covered by warranty, he should take the truck to a indy mechanic for an inspection, rather than a Toyota dealer.
