Tacoma Screeching noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Anthony250, Oct 31, 2010.
  1. Oct 31, 2010 at 9:38 PM
    Anthony250
    Anthony250 [OP] Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    My 99 Tacoma Prerunner V6 Auto, is running great but i hear a screeching noise, when i drive when you coast you can hear it , whe you give it light gas you can hear it, when you pick up some good speed you cant hear it, when you come to a stop the noise stops, its not a belt or nothing i checked that, i check brakes and still good sanded glaze off and pads and drums but still get the noise, i dont know what it is but its irritating me , wheel bearing ? somehitng else ?
  2. Oct 31, 2010 at 9:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How much front pad is left? Are they getting near the end of their life? Could be the wear indicators on the front pads that you are hearing.
  3. Oct 31, 2010 at 9:54 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  4. Nov 1, 2010 at 10:14 AM
    Anthony250
    Anthony
    Rialto CA
    The pads look new, and if it were a belt you can hear it amoung start up and its not that
  5. Nov 1, 2010 at 10:15 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    to me it really really sounds like a U-Joint
