Tacoma Service Truck Project
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aomeszaga, Jun 18, 2012.
  1. Jun 18, 2012 at 11:45 PM
    Aomeszaga
    Aomeszaga [OP] Member
    Hi guys, need some help finding reliable and proven ways to build my Tacoma service truck here's what i want.
    • engine air compressor
    • 10/20 gallon air tank in the bed mounted horizontally just behind the cab
    • pressure washer on top of the air tank on the driver side
    I need help finding an engine compressor that will fit my 5VZ FE
    ive already gotten the pressure regulator, sensors, switches, lines, etc planned out.
    Ive asked around and they talk about a volvo engine air comp that can be mounted with built brackets, just want to know if anyone out here has already done this or have an idea what is a good air comp
    thanks
  2. Jun 19, 2012 at 12:03 AM
    Cypherian
    Cypherian Well-Known Member
    Mid Atlantic Region
    2011 Dbl Cab TRD Sport
  3. Jun 19, 2012 at 1:11 AM
    Aomeszaga
    those look good for a fair price, i have a few questions
    1) AC Compressor CFM vs York Engine Mount Air Compressor CFM vs 12 Volt Air Comp CFM
    thinking of running air tools and maybe an 55gallon barrel oil pump off of the 20 gallon tank
    I think the 12 volt compressors will break keeping my 20 gal tank filled
    so im considering adding an air compressor pump to my engine or converting the ac
    ill go through the extra work of adding the pump so i can keep my ac maybe someone has ideas on how to plan it?
  4. Jun 19, 2012 at 8:13 AM
    Cypherian
    Mid Atlantic Region
    You would have to ask some one who has one I have yet to buy mine and install . Though needing air and pressure washer for continuous duty you may want to check into a gas powered compressor. I am not sure you wouldn't burn out a 12v. Maybe, consider setting up a small trailer to pick up a military one and set it up?
  5. Jun 21, 2012 at 12:22 AM
    Aomeszaga
    Damn, i bought a tundra instead of a tacoma and im gonna have an air zenith 2+2 system under my truck bed and an ingersol rand air comp/pressure wash combo in the bed, easiest way lol, thanks for backing up my research guys
  6. Jun 21, 2012 at 11:21 AM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    :confused:
    You didn't know what kind of truck you bought?
  7. Jun 23, 2012 at 1:29 AM
    Aomeszaga
    oh i was shopping for a truck and was considering a tacoma, but everyone called me a low baller so i bought a super clean tundra from some guy that works down the street from where i work. hmph their loss, that cash couldve been theirs. but yeah the tundra got massive power fit for a service truck lol
