Tacoma shakes after spark plug change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RRPACK, Mar 17, 2024.
  1. Mar 17, 2024 at 11:09 AM
    RRPACK
    RRPACK [OP] New Member
    I changed the spark plugs out with .40 gap. Truck shakes after start up and the yellow check engine light is still blinking on and off. Is there something else I need to do?
  2. Mar 17, 2024 at 11:12 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Bad plug? Need to scan for the misfire.
  3. Mar 17, 2024 at 11:15 AM
    jsi
    jsi Well-Known Member
    native earthling
    One of the plugs isn't connected. Don't ask me how I know :anonymous:
    grizquad, a400ryan, wilcam47 and 2 others like this.
  4. Mar 17, 2024 at 11:22 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are you using OEM stock Denso plugs?
    Mully likes this.
  5. Mar 17, 2024 at 12:00 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    Was the check engine light on before? If so the plugs were most likely not the issue. If not, Check wire to plug connection. There is a possibility you cracked the ceramic insulation of the plug on installation or the plug was bad to start. You may be able to get a code reader to tell you what cylinder is missing or unplug one spark plug at a time and see which cylinder makes the least difference unplugged
    wilcam47, AusBerg and TnShooter like this.
  6. Mar 17, 2024 at 12:02 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This^^^^
    Was the CEL flashing before the plug change?
    Until then, make sure all the coils are plugged in good.
    Those locking clips like to break off after years and years of heat cycles.
    If yours broke, use zipties to hold them together.
    Just "pushing them in" won't hold them in good enough.
    Steves104x4 and TacoJoeBro like this.
  7. Mar 17, 2024 at 12:12 PM
    Bishop84
    Bishop84 Well-Known Member
    I had a broken plug once cause this.
    But we need more info.
    TnShooter likes this.
  8. Mar 17, 2024 at 12:16 PM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    Did you use copper plugs or iridium? On iridiums, I’ve seen damage occur when checking/setting gap to either the tip of electrode or the little “disc” on the ground electrode gets broken off.
    Mully and Steves104x4 like this.
  9. Mar 17, 2024 at 1:42 PM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    Denso correct gap is .7 to .8mm. That is like .03”. For 3rd gen anyway
  10. Mar 17, 2024 at 2:05 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Gap specified in the 2nd gen user manual should be 0.044”.
  11. Mar 17, 2024 at 2:11 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    I'm guessing one or more of the coil connectors are disconnected or not fully seated
