TACOMA SHAKING PROBLEM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lordviews, Oct 1, 2022.
  1. Oct 1, 2022 at 3:39 PM
    lordviews
    lordviews [OP] Well-Known Member
    07 TRD Sport
    Hello. I have an 07 TRD Sport AUTOMATIC. There is a strange vibration when my transmission shift gears. It's usually from 1 to gear 2 and when going 25mph. It begins to do it a little when I reach 40mph as well. This mainly happens when I slowly accelerate. It doesn’t do it when I accelerate fast. I read around and tried literally everything. From changing u joints to the carrier bearing. Two mechanics couldn’t diagnose the problem and the truck read no codes. I did read however that replacing the transmission oil will fix it. So I recently replaced my transmission oil and drained the old one out as well as replaced the filter. My truck stopped doing it as bad and doesn’t do it when it’s cold. Idk if I’m just over thinking it. Could it be because I needed to do a full transmission flush? I also read on this thread that it could be my spark plugs? I really don’t know what to do now.
  2. Oct 1, 2022 at 4:24 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  3. Oct 1, 2022 at 4:24 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Typical rumble strip. I fixes mine with a full transmission flush plus a lubeguard additive.
  4. Oct 1, 2022 at 4:35 PM
    lordviews
    07 TRD Sport
  5. Oct 1, 2022 at 4:36 PM
    lordviews
    07 TRD Sport
    Damn do you think I can recycle the new fluid I just put in? It was pretty pricey since it was straight from the dealer.
  6. Oct 1, 2022 at 5:06 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    If you already replaced u joints, I would check wheel balance, wheel bearings (if turning makes it better/worse), front diff bearing if you’re 4x4.
    it’s not your spark plugs.
    if your transmission fluid is at the correct level that shouldn’t be the issue. I wouldn’t use any additives to try to solve the problem.
    Are you 4x4?
    how many miles on it?
  7. Oct 1, 2022 at 7:29 PM
    lordviews
    07 TRD Sport
    Hey man I’m at 120 and it’s not a 4x4. Seems like everyone is pointing me to additives? What’s the pros and cons to that? Seems like that’s my last option tbh. No mechanic is helping me figure it out either.
