Tacoma Shock Relocation - Trail Series - 2.0 x 12 - 2nd/3rd gen
Discussion in 'Archive Garage' started by ARCHIVE, Feb 22, 2021.
  1. Feb 22, 2021 at 3:15 PM
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    • TW members get 5% discount (start conversation for code)
    • LEAD TIME: IN STOCK
    • INSTALL AXLE TABS @ MAX BUMP HEIGHT
    https://archivegarage.com/products/2005-2023-tacoma-shock-relocation-trail-series-2-0-x-12-to-14
    For the Tacoma owners who need articulation for their trail or rock focused rig, and want quality shocks, but don't need 2.5" shocks, we offer our new Trail Series 2.0" relocation kit.
    Fitment info:
    -It does NOT fit 2.5" shocks
    -Tabs top and bottom are standard 1.5" width w/ 1/2" bolt.
    -Ideal collapsed length between 18"-21" (axle tabs rotate to adj)
    -Remote reservoir & straight hose only, piggyback will not fit
    -Wheel spacers may not be needed with negative offset wheels, depending on tire size and brand ex:
    16x8 et0 4.5" BS w/285s or
    17x9 et-38 3.5" BS w/315s or
    17x7.5 et15 (FJ) 4.75" BS w/265s
    -The recommended shock is a Fox Performance series 2.0x12 (18.35" collapsed) remote reservoir (resi cannot mount to shock body, tuned by Accutune):
    https://accutuneoffroad.com/product/fox-2-0-x-12-performance-series-remote-reservoir/
    Remote reservoir with adjuster:
    https://accutuneoffroad.com/product...ies-remote-reservoir-12-1-travel-cd-adjuster/
    After running Accutune'd Fox 2.0x12 on one of my trucks, I was happy with the good ride and moderate performance for only about $620 /pair which included custom valving!
    It will also fit:
    -Fox Performance series 2.0x14 (20.8" collapsed, loss in ground clearance vs. 12", rotate axle tabs down to adj)
    -King 2.0x12 (19.6" collapsed),
    -Radflo 2.0"x12" 5SR-003-00 (With 5/8" rod)
    -Radflo 2.0"x12" 5SR-007-00 (With 7/8" rod)
    -ADS 2.125x12
    Kit comes welded ready to install. 1/4" Hi strength steel construction and CNC formed
    @ZebraScissors
    @Glenn_R (DCSB frame, shown at full droop)
    @EatSleepTacos (Access cab frame, at ride height)
    GHammer, Glueman, lo2hi and 15 others like this.
  2. Feb 22, 2021 at 3:43 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    Sweet! Looking forward to seeing this
    ARCHIVE[OP] and mcharfauros like this.
  3. Feb 22, 2021 at 3:57 PM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Owweeee
    ARCHIVE[OP] likes this.
  4. Feb 22, 2021 at 4:16 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    These things look amazing!!!!
    EatSleepTacos likes this.
  5. Feb 22, 2021 at 4:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Especially amazing peeking through the wheel well!
  6. Feb 22, 2021 at 5:28 PM
    crashngiggles
    Jared
    Either Randy or @ARCHIVE (Eric) I know that Fox, King, or ADS are recommended with these, but how about the 12 inch 2.0 bilstein resi?
  7. Feb 22, 2021 at 5:30 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As long as the mounts are 1.5” wide and uses 1/2” diameter bolts, then I don’t see why it wouldn’t work. I do recall a friend saying the spacing on his billies was something funky and had to stack some washers in his to get that 1.5”.
    mcharfauros likes this.
  8. Feb 22, 2021 at 5:31 PM
    crashngiggles
    Jared
    Got those in the mail as we speak :).....the spacers I mean
    EatSleepTacos[QUOTED] likes this.
  9. Feb 22, 2021 at 5:32 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    And in case anyone is unsure what I mean by the 1.5”, it’s the combined width of the shock mount and the spacers that come with it.
    Aka the space between my fingers
  10. Feb 22, 2021 at 6:10 PM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Is the advantage of this relocation over your other that you wouldn’t need to run wheel spacers? I have your older kit on my truck and I love it
    mcharfauros and biborado like this.
  11. Feb 22, 2021 at 6:37 PM
    ARCHIVE
    Eric
    It is more affordable, you can get Fox RR 2.0x12 and the relo kit for $800 all in. Because there is no concern over fitting any bypass tubes like my other tower, and its only 2.0 body shocks, it may be able to run without wheel spacers with certain offset aftermarket wheels and 285s
  12. Feb 22, 2021 at 6:43 PM
    ARCHIVE
    Eric
    Personally, after giving my money to Bilstein, and being very dissatisfied, I cannot recommend them to anyone. (But people can, it is best to get collapsed length between 18-20", don't know Bilstein lengths)
    -I recommend good rebuildable and tuneable Fox Performance series 2.0x12.1 and only 18.35" compressed for $560/pair. (Remote resi cannot mount to shock)
    With adjuster:
    bprout, mcharfauros and GHOST SHIP like this.
  13. Feb 22, 2021 at 9:24 PM
    WestCoastMango
    WestCoastMango Well-Known Member
    Anthony
    Vancouver Island
    2019 DCSB
    Nice! Happy to see more affordable options for people to kit out their yotas. Jeeps better start watching out :)
  14. Feb 23, 2021 at 9:42 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Got these sitting at the house for a different 2.0 setup. Wish these had come out sooner. Darnit lol. Looks great! Great job Eric!
    whatstcp likes this.
  15. Feb 23, 2021 at 10:13 AM
    Mohedano1
    Mohedano1 Well-Known Member
    Ogden, Utah!!
    '15 4wd DCSB TRD Offroad
    Total Chaos uca, King 700lb extended coilovers, King Tundra rear shock w/resi, BruteForceFab Hybrid front bumper, BruteForceFab rear HC bumper, BAMF skidz. 315/75/16 cepek extreme country, 4.88 gears, front arb locker. Rci sliders and diff skid
    I currently have 07+ tundra 2.5 kings with 10" travel, dakar leafs and hammer hangars. Would your recommended setup work with the dakar? Will dakars flex enough to benefit from the longer shock? Thanks!!
  16. Feb 23, 2021 at 10:18 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ooo I can answer this. I had Dakar’s, hammer hangers and 12” kings and it flexes awesome.
    You’ll want to trim the second leaf on the Dakar’s back an inch or so though because under a lot of flex, the leaf pack fans out and the second leaf gets jammed into the shackle.
    https://www.instagram.com/p/CBbG34kAT1v/?igshid=4ry4ozp1ozkn
  17. Feb 23, 2021 at 10:21 AM
    Mohedano1
    Ogden, Utah!!
    Awesome, thanks for the response!! I trimmed the dakars years ago after my hammer hangar install and posted pics and info.
  18. Feb 23, 2021 at 10:27 AM
    Mohedano1
    Ogden, Utah!!
  19. Feb 23, 2021 at 10:29 AM
    Mohedano1
    Ogden, Utah!!
    I get ok flex now
  20. Feb 23, 2021 at 10:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have those same shocks you asked about above but without the clicker compressor.
