Tacoma shock
Discussion in '1st Gen. Tacomas (1995-2004)' started by Patrickaudish, Apr 5, 2020.
  1. Apr 5, 2020 at 11:24 AM
    Patrickaudish
    Patrickaudish [OP] Well-Known Member
    Patrick
    2002 Tacoma
    Lift, method rims, big tires.
    I installed 5100 bilstein on my 2002 Tacoma. I have this problem right now.
  2. Apr 5, 2020 at 11:27 AM
    tcjacado
    tcjacado Well-Known Member
    Undo the uca ball joint then push down on the lca with you foot and put a pry bar under the shock eyelet and in the shock mount. Push up on the pry bar and the shock eye will slide in.
    Also fix that dam upper ball joint ffs
    Maximo_23 and Taco-Obsessed like this.
  3. Apr 5, 2020 at 11:28 AM
    Taco-Obsessed
    I had a similar issue with a rear shock. I used a bolt and nuts. Put it through and turned the nuts to spread the shock mount apart. Make sense?
    After getting the shock in I tightened it back down, bending the mount back in place correct for the shock.
    However, being the LCA can move, with a second person you should be able to push down the LCA and push the shock into the lower mount.
    tcjacado likes this.
  4. Apr 5, 2020 at 11:29 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Looks like you have a torn boot from here. On the UCA.
    3JOH22A likes this.
  5. Apr 5, 2020 at 11:30 AM
    eon_blue
    Azusa, CA
    Ditch the spacer and it'll fit no problem
    Also you need a new upper ball joint
  6. Apr 5, 2020 at 11:31 AM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    5100s and a spacer? What do you have the 5100s set on?
    whatstcp likes this.
  7. Apr 5, 2020 at 11:32 AM
    tcjacado
    Looks like 0. Bottom clip
  8. Apr 5, 2020 at 11:34 AM
    Taco-Obsessed
    OP - I agree with this too (loose the spacer), but didnt want to assume so because for all I know its intended use is a street truck and for looks.
  9. Apr 5, 2020 at 11:35 AM
    Taco-Obsessed
    Oooff
    tcjacado[QUOTED] likes this.
  10. Apr 5, 2020 at 11:53 AM
    Stang0787
    Stang0787 Member
    Rudy
    Fairfield, Ca
    2020 Tacoma TRD OR
    Kings 3” lift
    Thos are the 5100’s you can see the groves for the height adjusters in the picture
  11. Apr 5, 2020 at 11:55 AM
    Patrickaudish
    Patrick
    2002 Tacoma
    I put the height on the shock to 0 so I should be able to put the spacer on cause it’s the same highs as the stock ones.
  12. Apr 5, 2020 at 12:00 PM
    Taco-Obsessed
    You consider just ditching the spacer all together?
  13. Apr 5, 2020 at 12:07 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Use a pry bar to push/pull the entire assembly down. Then you should be able to slip the bolt through.
  14. Apr 5, 2020 at 12:08 PM
    Patrickaudish
    Patrick
    2002 Tacoma
    We did. It’s not moving as much.
  15. Apr 5, 2020 at 12:20 PM
    Taco-Obsessed
    If you decided to keep the spacer and can't get the LCA to move down with another person helping after undoing the UCA ball joint, then you could spread the lower shock mounts further apart to get it to slide in. Slide a bolt through with two nuts on the inside of the lower mounts. Then move them so they are each on one of the inner side of the mounts. Turn the nuts one at a time to move the nuts out further/away from each other slightly bending the mounts outwards. Once you get the shock in you can tighten them back down to fit the shock.
  16. Apr 5, 2020 at 1:44 PM
    iunek808
    iunek808 Well-Known Member
    oahu
    04 tacoma dblcab prerunner 4x4
    Tundra 5100's w/Fj springs Deaver leafs 4x4 conversion w/manual hubs Jshift
    Unbolt the LBJ and use a ratchet strap hooked on lower control arm close to LBJ (not on the Ball joint) and wrap the other end of strap to opposing side (i wrap around the lower shock). That will help u bring the lower control arm down instead of having a second hand pushing down and fighting to get that lower bolt in lol
    Taco-Bell and Taco-Obsessed like this.
  17. Apr 5, 2020 at 2:20 PM
    Taco-Obsessed
  18. Apr 5, 2020 at 2:23 PM
    Patrickaudish
    Patrick
    2002 Tacoma
    Not yet but one of you guys is helping me. Thank god for him
  19. Apr 5, 2020 at 2:24 PM
    tcjacado
    Where are you located?
  20. Apr 5, 2020 at 2:27 PM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    The problem appears to be the massive spacer :rofl:
    Sreppep and Blue92 like this.
