Tacoma shuts off while driving. Please help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddie2nv, May 8, 2017.
  1. May 8, 2017 at 7:41 PM
    Reddie2nv
    Reddie2nv [OP] Well-Known Member
    Charlotte NC
    08 PreRunner TRD Off Road
    My truck will randomly shut off with no warning at all. When it does stall everything electrical is still on (radio, lights etc.).its almost like i just turned the the truck off while driving. Also on occasion when this happens it wont just start back up. There is a no crank no start moment. Any advice on this would be greatly appreciated.
  2. May 8, 2017 at 7:43 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Have you plugged in a scan tool to check for any codes? And not just a basic code reader that Oreilly's or autozone uses. One that can see if there are not only current, but pending and history codes as well. That's where I'd start
  3. May 8, 2017 at 7:43 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Check engine light on? When the MAF sensor was going bad on my older Tacoma it would randomly stall like you describe, but it would start back up again.
  4. May 8, 2017 at 7:49 PM
    Reddie2nv
    Charlotte NC
    No code no CEL
  5. May 8, 2017 at 7:51 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    I would think fuel pump. Though you are saying you are not getting a crank at all when you try to restart? Loose battery negative or ground?
    12TRDTacoma and outlawtacoma like this.
  6. May 8, 2017 at 7:52 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Loose battery cable? I had one on a truck that would occasionally rattle loose and the truck would die and not start until I tightened it back down. Everything electrical in the truck still functioned but it just wasn't a good enough connection to energize the starter.
    12TRDTacoma and lynyrd3 like this.
  7. May 8, 2017 at 7:53 PM
    Reddie2nv
    Charlotte NC
    New battery and i checked all the grounds. It doesnt happen when turning or hitting a bump from what i can tell. Its completely random. Ive checked every fuse and relay that would relate to it. I cant figure it out.
  8. May 8, 2017 at 7:55 PM
    tcjacado
    tcjacado Well-Known Member
    Could it be with the ignition module going bad?
  9. May 8, 2017 at 7:56 PM
    Reddie2nv
    Charlotte NC
    It will somtimes shut off at idle in park.
  10. May 8, 2017 at 7:57 PM
    Reddie2nv
    Charlotte NC
    Thats what i was thinking jacado but will that cause a stall while driving?
  11. May 8, 2017 at 7:58 PM
    Caligula
    Los Angeles, CA
    Check again for codes and pending codes.
    txtaco87 likes this.
  12. May 8, 2017 at 7:58 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Check crankshaft position sensor
    Caligula likes this.
  13. May 8, 2017 at 8:00 PM
    Reddie2nv
    Charlotte NC
    Ive checked for codes everytime its happened. Last time was a couple months ago.
  14. May 8, 2017 at 8:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It shuts off when you're on the throttle or idling?
  15. May 8, 2017 at 8:01 PM
    chrisrocks300
    Brandon, MS
    Does it have to cool down some before you can start it back up? Another sign it could be cps
  16. May 8, 2017 at 8:01 PM
    Reddie2nv
    Charlotte NC
    If it was the crank shaft position sensor wouldnt it try to crank?
  17. May 8, 2017 at 8:01 PM
    Caligula
    Los Angeles, CA
    The last time this happened was a couple of months ago?
  18. May 8, 2017 at 8:02 PM
    tcjacado
    If there is a loose wire yes it will cause it short and stall out and then wouldn't restart if the short is still present. Once it cools down some short maybe corrected for the time being.
  19. May 8, 2017 at 8:02 PM
    Reddie2nv
    Charlotte NC
    It has shut off both at idle and while on the gas.
  20. May 8, 2017 at 8:03 PM
    tcjacado
    How worn is your ignition key and housing. This could also pose a problem.
