Tacoma shuts off while driving. Please help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddie2nv, May 8, 2017.
  1. May 8, 2017 at 8:04 PM
    tcjacado
    tcjacado Well-Known Member
    Fuel pump? Is also something I would check. Never know with these things.
  2. May 8, 2017 at 8:05 PM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    Had this same thing happen to me today. Died while in neutral shifting from 1st to reverse. Wouldn't turn over for a minute. Waited and it finally cranked. Battery cables good. Idk.
  3. May 8, 2017 at 8:05 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    No, that's one of the sensors that if a signal is missing, it will not even allow cranking. The others include cam position sensor, oil pressure, and sometimes the MAF or MAP depending on the car.
    I would say fuel pump first if your engine was at least cranking.
  4. May 8, 2017 at 8:05 PM
    tcjacado
    That would throw a cel code for sure
  5. May 8, 2017 at 8:05 PM
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    Also maybe IAC valve?
  6. May 8, 2017 at 8:05 PM
    Reddie2nv
    Reddie2nv [OP] Well-Known Member
    Charlotte NC
    08 PreRunner TRD Off Road
    I first changed the efi relay months ago and thought that fixed it butit didnt.
    tcjacado likes this.
  7. May 8, 2017 at 8:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ignition relay or module, maybe
  8. May 8, 2017 at 8:06 PM
    Reddie2nv
    Charlotte NC
    I cleaned the tb and was just checking on the IAC. Would that cause a no crank situation?
  9. May 8, 2017 at 8:07 PM
    tcjacado
    Sorry op. I am throwing stuff out there... not exactly sure. Never had this happen with my 07. I am terrified of all the computers in this 17.
  10. May 8, 2017 at 8:08 PM
    Reddie2nv
    Charlotte NC
    Could it be the neutral safety switch?
  11. May 8, 2017 at 8:08 PM
    chrisrocks300
    Brandon, MS
    By the way quick question do you go under like 800 rpms right before it stalls
  12. May 8, 2017 at 8:09 PM
    tcjacado
    Some one on here is smarter than us and will chime in soon as long as we can keep this thread on the front page. Lol
  13. May 8, 2017 at 8:09 PM
    chrisrocks300
    Brandon, MS
    Lol true
    tcjacado[QUOTED] likes this.
  14. May 8, 2017 at 8:11 PM
    Reddie2nv
    Charlotte NC
    It does seem to idle low. Thats why i cleaned the TB.
  15. May 8, 2017 at 8:12 PM
    #35
    Reddie2nv
    Charlotte NC
    What is a normal rpm at idle?
  16. May 8, 2017 at 8:13 PM
    #36
    chrisrocks300
    Brandon, MS
    Check the iac, it could be contributing to this. My vote since there is no cel is that your fuel pump is bad or it is the iac, I do wish you luck though and I'm sorry if I couldn't help more
  17. May 8, 2017 at 8:14 PM
    #37
    Reddie2nv
    Charlotte NC
    Definitely next on the list thanks Chris.
    chrisrocks300 likes this.
  18. May 8, 2017 at 8:14 PM
    #38
    tcjacado
    There are other forums too op, type your symptoms or issue into Google and begin the long reading process.
  19. May 8, 2017 at 8:15 PM
    #39
    tcjacado
    I was just reading on another forum not tw guy was having issue with EGR valve.
  20. May 8, 2017 at 8:15 PM
    #40
    Reddie2nv
    Charlotte NC
    Trust me i have read everything and watched every video. Thats why im asking here.
