Tacoma shuts off while driving. Please help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddie2nv, May 8, 2017.
  1. May 8, 2017 at 8:16 PM
    #41
    tcjacado
    tcjacado Well-Known Member
  2. May 8, 2017 at 8:16 PM
    #42
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    If you can't figure it out you could always take it to Toyota, they can hook it up and look for more codes there
  3. May 8, 2017 at 8:17 PM
    #43
    Reddie2nv
    Reddie2nv [OP] Well-Known Member
    Charlotte NC
    08 PreRunner TRD Off Road
    Toyota is my last resort but if it come down to it i gotta do what i gotta do.
  4. May 8, 2017 at 8:17 PM
    #44
    chrisrocks300
    Brandon, MS
    How many miles does your truck have on it by the way?
  5. May 8, 2017 at 8:18 PM
    #45
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    OP - do you have any more detail of when or the conditions the truck does this? I know for crankcase position sensors it's usually after driving the vehicle for some time in hot weather.
  6. May 8, 2017 at 8:18 PM
    #46
    tcjacado
  7. May 8, 2017 at 8:20 PM
    #47
    Reddie2nv
    Charlotte NC
    Ive been on a lot of dirrerent searches for this specific problem. Everyone has a crank but no start or the car starts to sputter then shuts off. Im lost right now. I even tried different keys bc i thought the chip was going bad in my master key.
  8. May 8, 2017 at 8:21 PM
    #48
    Reddie2nv
    Charlotte NC
    Juat recently it happened within 5 minutes of driving if that helps.
  9. May 8, 2017 at 8:22 PM
    #49
    chrisrocks300
    Brandon, MS
    Have you considered you may have killed your battery trying to start it because of the issue? Was it cranking before? My aunt had a similar problem, try taking out the drop in air filter and leave the hood up with it out. Try starting it, if it starts it could be a fuel pump problem
    Edit: if you need to jump the car
    tcjacado likes this.
  10. May 8, 2017 at 8:24 PM
    #50
    Reddie2nv
    Charlotte NC
    No i replaced the battery after the first few times it happened months ago. After it started happening again i tested the battery and alt. Both are fine.
  11. May 8, 2017 at 8:26 PM
    #51
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You re right to clean the TB. Trying moving the ign key forward through it's spots slowly while jiggling. If the ign switch is developing a bad spot the dash lights might blink on and off quickly.
  12. May 8, 2017 at 8:26 PM
    #52
    chrisrocks300
    Brandon, MS
    Seriously, try opening taking out your air filter and starting the truck. Leave the latch open, see if it starts. If it does there's a good chance it could be a fuel pump problem. If not that indicates it might not be, little hack lol
  13. May 8, 2017 at 8:28 PM
    #53
    Reddie2nv
    Charlotte NC
    Wouldnt a failing pump cause it to sputter and would also try to crank?
  14. May 8, 2017 at 8:29 PM
    #54
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You don't have a fuel pump problem
    12TRDTacoma likes this.
  15. May 8, 2017 at 8:31 PM
    #55
    Reddie2nv
    Charlotte NC
    I know there is a pump safety switch but i wasnt sure if that would cause this.
  16. May 8, 2017 at 8:31 PM
    #56
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you say if it would no crank?
  17. May 8, 2017 at 8:32 PM
    #57
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When it won't start does it crank and not start or does it not even crank?
  18. May 8, 2017 at 8:32 PM
    #58
    Reddie2nv
    Charlotte NC
    No crank. Sometimes starts right up. Sometimes no click or anything that i can tell
  19. May 8, 2017 at 8:34 PM
    #59
    Reddie2nv
    Charlotte NC
    Its almost like its a theft security issue or aomething
  20. May 8, 2017 at 8:34 PM
    #60
    tcjacado
