Tacoma shuts off while driving. Please help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddie2nv, May 8, 2017.
  1. May 8, 2017 at 8:34 PM
    #61
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    No click hmm.. when it dies does it shut off electrically like dark dash board or does the engine shut off?
    tcjacado likes this.
  2. May 8, 2017 at 8:35 PM
    #62
    Reddie2nv
    Reddie2nv [OP] Well-Known Member
    Charlotte NC
    08 PreRunner TRD Off Road
    But ive looked into that and i cant find it that would cause a stall while driving
  3. May 8, 2017 at 8:36 PM
    #63
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When it stalls do you lose all the lights on the dash?
  4. May 8, 2017 at 8:36 PM
    #64
    Reddie2nv
    Charlotte NC
    Engine dies no power steering every thing else stays on. Radio lights everything.
  5. May 8, 2017 at 8:37 PM
    #65
    Reddie2nv
    Charlotte NC
    All gauges drop but lights stay on.
  6. May 8, 2017 at 8:37 PM
    #66
    tcjacado
    tcjacado Well-Known Member
    Could be as simple as a distributor cap, rotor??
  7. May 8, 2017 at 8:41 PM
    #67
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Ok that could be a fuel pump LOL but before you panic and buy a pump you should clean the maf sensor. Also you were right to check battery and alt connections too I hope.. Also look in dude box and make sure you don't have a loose but on one of those bigger battery power cables in the fuse box. Grab the cables and flex them around, they might be loose but you gotta put your hands o them to know feel me..
    YOU could put a fiel pressure gauge on it and try too catch the fuel pump slipping but my mokney is on a dirty or bad maf or loose electrical connection.
  8. May 8, 2017 at 8:41 PM
    #68
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    LOL distributor cap!?
  9. May 8, 2017 at 8:42 PM
    #69
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    ..fuse box not dude box..
  10. May 8, 2017 at 8:43 PM
    #70
    Reddie2nv
    Charlotte NC
    Would it help to get a bluetooth obdll and see if it catches it next time it happens?
  11. May 8, 2017 at 8:44 PM
    #71
    Reddie2nv
    Charlotte NC
    Yeah dude box was new to me but i was like whatever...pretty sure you were talking about the fuse box.
  12. May 8, 2017 at 8:44 PM
    #72
    tcjacado
    Not really a mechanic as you might have guessed. Just a sounding board and sometimes I sound stupid.
  13. May 8, 2017 at 8:44 PM
    #73
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes..
    Sorry I type slow LOL..
  14. May 8, 2017 at 8:44 PM
    #74
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's all good
    tcjacado[QUOTED] likes this.
  15. May 8, 2017 at 8:46 PM
    #75
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    This is fixable.. don't be afraid to grab wiring and flex on hoses and stuff.. while it's running! If you grab a pcv hose that is soggy and leaking it will make the engine die right in front of you. Did you check the ignition switch lik e I mentioned?
  16. May 8, 2017 at 8:46 PM
    #76
    tcjacado
    I am learning like the rest of the newbies, don't have my 07 anymore so no real need to worry about this issue. I got bigger problems with figuring out this 17 I got now.
  17. May 8, 2017 at 8:47 PM
    #77
    Reddie2nv
    Charlotte NC
    Ill try to check all connections and clean tb and maf tomorrow. Thanks for all the advice guys. Let you know what i find out.
  18. May 8, 2017 at 8:49 PM
    #78
    Reddie2nv
    Charlotte NC
    I did check the ignition switch. But would that cause a stall also?
  19. May 8, 2017 at 8:52 PM
    #79
    tcjacado
    I would have to say yes. It makes a battery connection, which is good. Problem is after that.
  20. May 8, 2017 at 8:52 PM
    #80
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Absolutely.. all the power for the car ultimately goes through the switch (acc, run, crank,) if you bump it with your knee or it just shifts around (they loosen up over time, you stick the key in it every day for 10 years) and it can lose contact for a split second , then go back to working
    12TRDTacoma and tcjacado like this.
