Tacoma shuts off while driving. Please help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddie2nv, May 8, 2017.
  1. May 8, 2017 at 8:53 PM
    #81
    tcjacado
    tcjacado Well-Known Member
    On my 07, my key was so worn I could start the truck then pull the key out with everything still running like an old vw bug
  2. May 8, 2017 at 8:54 PM
    #82
    Reddie2nv
    Reddie2nv [OP] Well-Known Member
    Charlotte NC
    08 PreRunner TRD Off Road
    I bought the truck used from the dealership. Could it be an issue if the previous owner had an aftermarket alarm?
    12TRDTacoma likes this.
  3. May 8, 2017 at 8:54 PM
    #83
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    And clean the throttle body.. I cannot stress this enough! All around the plate and the edges of the plate.. tb cleaner on a rag.
  4. May 8, 2017 at 8:55 PM
    #84
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Alarm will only keep it from starting won't make it stall.
    tcjacado likes this.
  5. May 8, 2017 at 8:56 PM
    #85
    tcjacado
    Do not stick any object in the throttle body. This I know for a fact can mess it up. Do some research on how to do it properly if you don't already know how.
  6. May 8, 2017 at 8:57 PM
    #86
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Use the handle end of a screw driver to hold it open
    tcjacado[QUOTED] likes this.
  7. May 8, 2017 at 8:57 PM
    #87
    Reddie2nv
    Charlotte NC
    I dont move the valve. I know it can mess up the actuator.
  8. May 8, 2017 at 8:58 PM
    #88
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    YOU can open the plate it's ok.. you have to to get the gunk out
  9. May 8, 2017 at 8:58 PM
    #89
    tcjacado
    I have seen the out comes of a couple of guys that used a flat head screw driver to pry it open. Wasn't a good out come
  10. May 8, 2017 at 8:58 PM
    #90
    Reddie2nv
    Charlotte NC
    I take the whole tb off and clean it not moving the valve. I messed up my infinity like that before. Not sure if its the same with a taco but better safe then sorry.
  11. May 8, 2017 at 8:59 PM
    #91
    Reddie2nv
    Charlotte NC
    Infiniti*
  12. May 8, 2017 at 8:59 PM
    #92
    tcjacado
    You have got this op!
  13. May 8, 2017 at 8:59 PM
    #93
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I use a small brass brush to gently brush throug the crud ring that builds up around the plate, with squirts of tb cleaner to keep it wet.. giggiddy..
  14. May 8, 2017 at 9:00 PM
    #94
    Reddie2nv
    Charlotte NC
    Well ill try to get it worked out thanks again ill let you guys know if i come up with a solution.
  15. May 8, 2017 at 9:01 PM
    #95
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    All I can think of is if the truck is running and then dies out of the blue and won't crank it sounds like it's something electronic rather than a physical part failure. If the battery were loose the lights on the dash would go out too, and those are staying on.
    It's got to be a sensor or the security system having a short.
    It's weird that it's an intermittent problem. Are the cables going to the starter good?
    I'd also check what the guys above said, maybe the ignition wires are frayed or the connection is loose.
  16. May 8, 2017 at 9:01 PM
    #96
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Why pry? Just push it open with your hand.. you have to get the crust ring out. That's the only way to get the airflow you need at idle
  17. May 8, 2017 at 9:03 PM
    #97
    Reddie2nv
    Charlotte NC
    I keep thinking security problem but again would that cause a stall?
  18. May 8, 2017 at 9:03 PM
    #98
    tcjacado
    I don't know why they pried it open but that's what they did and it then needed to be replaced.
  19. May 8, 2017 at 9:04 PM
    #99
    tcjacado
    Thanks for chiming in.
    eccracer104[QUOTED] likes this.
  20. May 8, 2017 at 9:05 PM
    #100
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    As the crud ring builds up the plate opens farther and farther to compensate and sustain enough airflow for idle. If you pull the battery cable the plate goes back to square 1.. buried in the crud ring.. it will idle super low, it will hunt, it will want to stall, and it will crank no start or crank and quickly stall, next time it happens try feathering the t rhottle..
