Tacoma shuts off while driving. Please help.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reddie2nv, May 8, 2017.
  1. May 9, 2017 at 6:16 AM
    #101
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I'm wondering if the physical ignition switch itself has issues... Just a thought
  2. May 9, 2017 at 8:12 AM
    #102
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Bump. Any updates OP?
    tcjacado likes this.
  3. May 9, 2017 at 8:21 AM
    #103
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    I don't know if you've figured it out yet, but my wife and I had a CRV that would randomly shut off at times (once or twice a month). Chased it down for a year and couldn't figure it out. Ended up being the ignition module.
  4. May 9, 2017 at 8:25 AM
    #104
    PoweredBySoy
    Jesse
    Minnesota
    2013 DCSB SR5
    Agree. We had the same symptoms.
    eccracer104[QUOTED] likes this.
  5. May 9, 2017 at 9:24 AM
    #105
    tcjacado
    tcjacado Well-Known Member
    I
    Had a crx that would blow one of those every 6 months. I would hit the dots changing lanes and kapow engine would die
  6. May 9, 2017 at 9:27 AM
    #106
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea but those are on distributor systems. OP has coil on plug..
    tcjacado[QUOTED] likes this.
  7. May 9, 2017 at 9:28 AM
    #107
    tcjacado
    Yeah we kind of hit on that last night. Right? Lol
  8. May 9, 2017 at 9:40 AM
    #108
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's coo.. where s OP? we're the only ones keeping this going..
    eccracer104 likes this.
  9. May 9, 2017 at 10:03 AM
    #109
    tcjacado
    Idk I guess busy at the moment.
  10. May 9, 2017 at 10:18 AM
    #110
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I've seen a post like this before either here or another forum and turned out to be a dealer installed aftermarket alarm that the OP didn't know was installed. I do know that most dealerships out here pre-install these cheap alarms and disable it if you don't purchase. I purchased new cars before with these pre-installed alarms that was disabled and the first thing I do when I get home is take them off and clean up the wiring.
  11. May 9, 2017 at 11:26 AM
    #111
    redcon
    redcon Well-Known Member
    Dave
    Southern PA
    2012 AC 4x4 Base 2.7L/5MT
    Not much to add, except that I had a very similar problem with my 1998 GMC Sonoma, which led me to sell it and purchase my Tacoma.
    I troubleshot that truck for 1.5 years before I threw in the towel.. new ignition switch, coilpacks, plugs & wires, Ignition control module, traced every ground, etc.
    The previous owner disabled the factory security system and I always felt that was the root cause, although I never did trace it down.
    OP... keep us updated.
  12. May 9, 2017 at 11:28 AM
    #112
    Reddie2nv
    Reddie2nv [OP] Well-Known Member
    Charlotte NC
    08 PreRunner TRD Off Road
    Well as of now im trying to change the crank sensor. But im not sure where it is.
  13. May 9, 2017 at 11:29 AM
    #113
    Reddie2nv
    Charlotte NC
    It does look like there was at one point an aftermarket alarm.
  14. May 9, 2017 at 11:36 AM
    #114
    Reddie2nv
    Charlotte NC
    Anyone know exactly where the crankshaft position sensor is located?
  15. May 9, 2017 at 11:40 AM
    #115
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Hopefully this will help -
    found here - https://www.tacomaworld.com/threads/crankshaft-position-sensor-replacement-p0018-obd-code.294296/
  16. May 9, 2017 at 11:41 AM
    #116
    Reddie2nv
    Charlotte NC
    Awesome thanks.
  17. May 9, 2017 at 11:56 AM
    #117
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you're at the parts store getting a crank sensor a little handheld code reader with some data would be well worth the money maybe a hundred bucks or so. The next time the truck stalls and it won't restart look at the data on the scan tool and see if you have an engine RPM signal. If you have an RPM signal the crank sensor is working..
  18. May 9, 2017 at 3:03 PM
    #118
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I'd inspect those wires under the dash first behind the steering wheel to see if the alarm box is still there. It could most likely be the cause before replacing sensors.
  19. May 9, 2017 at 3:34 PM
    #119
    chrisrocks300
    chrisrocks300 War Eagle
    Brandon, MS
    2016 4x4 Tacoma DCSB Trd Off-road Superwhite
    Total Chaos UCA's, Raceline Raptor wheels (16x8) 4.5 BS, 285/75/16 Cooper S/T Maxx tires, Icon Stage 2 Lift Kit, Sos sliders w/ fill plates, exhaust reroute, mobtown offroad skid plates (ifs, transmission, transfer case), and diff breather mod
    The irony in that statement
  20. May 10, 2017 at 2:55 PM
    #120
    Reddie2nv
    Charlotte NC
