Tacoma: Siphoning bad Gas (12v Gas Tapper siphon kit)
Discussion in 'New Members' started by Shirek4x4, Feb 18, 2021.
  1. Feb 18, 2021 at 10:11 PM
    Shirek4x4
    Shirek4x4 [OP] New Member
    JP
    17 TRD Tacoma
    If some of you have never been able to siphon gas out of a Tacoma, here is the real trick without the hard labor.
    Try the (12v Gas Tapper kit cost around 100.00 on ebay) that will get you by shutoff fuel valve in the tank in case of a roll over.
    The key to this little kit....1/2 clear nylon line. Thread the line into the gas filler port until it hits bottom, Then take the other 1/4 clear nylon hose with the bevel end and thread it through the 1/2 clear nylon tube. Once the 1/4 tube hits the fuel shutoff valve in the tank....wiggle it with forward pressure...it may be necessary to twist the tube in a circle a bit until it finds the gap in the fuel shutoff valve. Continue to push the 1/4 clear nylon tube until its into the bottom of the tank. Test the tube depth but blowing into the 1/4 tube....if you hear clear bubbles your in the bottom. Last, connect 1/4 nylon tube to the soft clear line that goes to the 12v fuel pump supplied .....then put your drain line into the container or can that will hold your bad fuel. Turn on the 12v pump connected to your cigarette lighter and empty that nasty fuel.
    Draining a Tacoma is easier than it seems if you use the right tools.
    EdgemanVA likes this.
  2. Feb 18, 2021 at 11:41 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Black DOG Lila likes this.
  3. Feb 19, 2021 at 5:11 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  4. Feb 19, 2021 at 8:07 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Thanks for the suggestion...just ordered one. I have a car that's been sitting for a couple years, and this beats having to crack the fuel tank open to remove the old gas. Want to get it back on the road this spring!
  5. Feb 19, 2021 at 8:14 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip: :cheers:
  6. Feb 19, 2021 at 8:16 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Just punch a hole in the bottom of the tank.
    Drain.
    Drill it out to accept a Fumoto valve.
    Install valve.
  7. Feb 19, 2021 at 12:37 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
