Tacoma Speedometer off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BillBluesFan, Jul 8, 2021.
  1. Sep 10, 2023 at 6:42 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Speedometer reads too fast, by about 2-3 mph @ 60 real mph... i.e. 4%
    The odometer reads correctly.
    Now, put on 1" taller tires and your speedometer will read correctly but your odometer will be slow or off about 4%.
    We with 265/70-16 tires stock change to 265/75-16 know this quite well!
  2. Oct 20, 2023 at 6:39 PM
    BOOMERZ
    BOOMERZ Member
    Lou
    2023 Icecap white Tacoma SX
    Not to beat a dead horse but on my 23 SR5 with the stock 245/75/16 tires it would read 1 to 2 mph faster than the GPS and road gps signs. Just swapped to 265/70/17 with the hypertech speedo calibrator and now it's 3 to 4 mph faster with the tire sizes entered. And my miles to empty has shot up to over 300.
    Might take it off and return it
  3. Oct 20, 2023 at 7:02 PM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    My 2015 tacoma reads 96 kph (gps) when doing 100 KPH.. Several of the cars I have driven are similar in overstating speed between 3 and 4 %
    It does help those who dont know about it avoid speeding tickets since if you think you are doing 120 kph on the 401 up here in Ontario you really only doing 115.
  4. Oct 20, 2023 at 7:52 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  5. Oct 20, 2023 at 9:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Speedometers, by desogn, can be off X percent. Tires wear and that changes speed. Going around corners changes speed. Approximate is good.
    musicisevil likes this.
  6. Oct 20, 2023 at 9:39 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    you mean to tell me my speedometer isn't as accurate as an atomic clock?
    Man, these tacomas are garbage!!
    Stevie17 likes this.
  7. Oct 20, 2023 at 10:17 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Wow...2017 still shows 385 to 410
  8. Oct 21, 2023 at 5:55 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Designed that way to keep the Man from getting all up in your Jimmies. Your welcome!
  9. Oct 21, 2023 at 5:59 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The way it works is the speedometer is about 3% fast while the odometer is usually dead nuts on. For your hypertech to make the speedo accurate, the numbers you program into it need to be right. Hyper tech has always fixed it well for me. The reason I returned my hypertech is it had a weird interference with my turn signals when I’d unlock the truck. Made me concerned about that thing being plugged in.
    If you simply upsized to 265/70R17, your speedometer should now read accurately while your odometer underreports by 3%. You go 100 miles on the dash, you actually went 103. Etc. I’d just return the HT and let the gauges be how they are with 265/70s.
  10. Oct 21, 2023 at 6:08 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
  11. Oct 21, 2023 at 6:14 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When I first drove my tacoma I noticed the odometer was reading fast...a mile was reading around .6 when I drove the truck through a measured mile on the highway. When I had my 1st toyotacare visit I complained about it. Whatever was done, did correct it when I drove off.
  12. Oct 21, 2023 at 6:55 AM
    babylon5
    David
  13. Oct 21, 2023 at 7:15 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    wheel size is irrelevant.
  14. Oct 21, 2023 at 7:41 AM
    babylon5
    David
    100% correct. Its the tire diameter. and you can have a 16 inch rim/tire that has same diameter of a lower profile 18 rim/tire
  15. Oct 21, 2023 at 7:51 AM
    #35
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Eight you’re great.
    Nine you’re mine.
  16. Oct 21, 2023 at 8:44 AM
    #36
    TA2016
    Oregon
    Very good point. Here is a fun Tire Size and Comparison calculator.
    https://www.blocklayer.com/tire-size-calculator
  17. Oct 21, 2023 at 8:58 AM
    #37
    Okkine 2.0
    Okkine 2.0 Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    Legally, the speedometer only needs to be accurate to within 5% (In Canada anyway. I'm guessing the US is the same), so most vehicles are off a little bit.
    You can use the mile markers that are on most highways to see if the odometer is accurate. Some highways here in Alberta even have designated odometer test markers.
  18. Oct 23, 2023 at 3:02 PM
    #38
    BOOMERZ
    BOOMERZ Member
    Lou
    What were the issues with your turn signals? I noticed lastt night that when I hit unlock the first time they dont activate, until i hit it the second time to unlock all doors. I thought there was something wrong with my Alpharex lights. I am one day out of the retun policy on the hypertech. :(
  19. Oct 23, 2023 at 3:31 PM
    #39
    BLtheP
    Plano, TX
    I found that mine DID unlock on the first click (the beep made its normal noise I believe but it’s been a while), but the turn signals didn’t illuminate. The second click I got the beep again and the turn signals did illuminate.
    I noticed when I removed the hyper tech it was pretty warm, not sure if that had anything to do with it or not but I felt better about removing it.
    I actually had a thread on this or I commented on an existing one (I don’t remember), but there were others who tested their hyper tech and they didn’t have that problem. I figured it was an automatic vs manual transmission thing, but if yours is automatic then I really don’t know.
    mine did this behavior with both a rough country programmer from rough country and another one from scamazon. Both acted exactly the same.
  20. Oct 23, 2023 at 3:38 PM
    #40
    BOOMERZ
    BOOMERZ Member
    Lou
    I just went out to look at the lights and what you just described is what its doing . It unlocks / beeps but the lights dont flash until the second time around.
    I guess im pulling it ouy and contacting Hypertech
