tacoma squeaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaV6, Nov 2, 2010.
  1. Nov 2, 2010 at 1:04 PM
    TacomaV6
    TacomaV6 [OP] Well-Known Member
    Bay Area
    1997 Tacoma 2WD v6
    Brush Guard Hid lighting Custom Prelude Fogs
    I am pretty sure its the suspension.
    cause when i hit bumps or when i turn it makes this awful sound.
    how do i lube it? and where
    >.< dont know how
  2. Nov 2, 2010 at 1:43 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    What tacoma? Where is the squeaking comming from?
  3. Nov 2, 2010 at 6:15 PM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Check the bushings at the bottom of the front shocks, if they are worn out they will be squeeky.
  4. Nov 18, 2010 at 6:29 PM
    saltbranch
    saltbranch Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    If its coming from the frontend...CHECK the ball joints. Before mine failed, they squeaked bad. Made a metal on metal noise, very loud when hitting bumps in the road and turning. If its from the front, jack up the truck till tires are off the ground, grab the tire at top and bottom and shake it hard, any movement its typically ball joints, side to side movement is typically tie rods/tie rod ends.
