Tacoma SR5 defrost issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcrain4x4, Sep 22, 2021.
  1. Sep 22, 2021 at 3:53 AM
    tcrain4x4
    tcrain4x4 [OP] Member
    terry
    Arkansas
    2001 tacoma 4x4 trd
    fabtech lift
    2001 Tacoma SR5
    Went to turn on defrost this morning and blowed cool air. Tried switching to my vents and it just blows very very little warm air. Mostly cool air. Any ideas what would cause this ? Thank y’all in advance
  2. Sep 22, 2021 at 4:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    Does the heater work? IE blow hot on your feet?
  3. Sep 22, 2021 at 4:16 AM
    tcrain4x4
    terry
    Arkansas
    2001 tacoma 4x4 trd
    fabtech lift
    Very very little if any
  4. Sep 22, 2021 at 4:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    Does the truck reach operating temperature? Running cold could be a tstat stuck open.
    Turning dial to highest heat, directional to dash vents, do you get heat there?
  5. Sep 22, 2021 at 4:26 AM
    tcrain4x4
    terry
    Arkansas
    2001 tacoma 4x4 trd
    fabtech lift
    Dial is on highest heat and fan is on highest position.. temp gauge shows at normal operating temp…
  6. Sep 22, 2021 at 4:41 AM
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
    are the Fans still working ? Pushing Air ?
  7. Sep 22, 2021 at 4:42 AM
    tcrain4x4
    terry
    Arkansas
    2001 tacoma 4x4 trd
    fabtech lift
    Yeah. Fans are blowing. Just cool air.
  8. Sep 22, 2021 at 4:53 AM
    MoonKnight
    chris
    First check the coolant level in the radiator. Check your heater core hoses on the firewall underneath the hood. Let the car come up to temp. and feel the two hoses. If only one of them is getting hot you may have bad heater core or a bad heater control valve
    stolen from another form
  9. Sep 22, 2021 at 4:53 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Check your coolant level.
  10. Sep 22, 2021 at 4:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    If it will blow heat out the dash vents you likely have a stuck or broken blend door.
    If you get no heat on any settings you likely have a coolant flow problem. Collapsed hose, clogged core, etc.
    If the truck isnt at 180+ temp (check with infrared) the tstat may be stuck open. The dash gauge isnt a reliable measure.
  11. Sep 22, 2021 at 4:43 PM
    tcrain4x4
    terry
    Arkansas
    2001 tacoma 4x4 trd
    fabtech lift
    Ok verdict so far… both hoses going in and going out of heater valve on fire wall is hot. I can have vents blowing and I have very warm air. I turn knob to dash defrost with or with the floor air and I have cool air. Plenty of coolant. Plus another question what controls the cable connected to the heater valve?
  12. Sep 22, 2021 at 5:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    Most likely a cable controling the blend door is the problem
    tcrain4x4[QUOTED][OP] likes this.
  13. Sep 22, 2021 at 5:25 PM
    Clearwater Bill
    Billy
    Largo Florida
    Also note you are in the 2nd gen forum with a 1st gen problem. Searching there will give you more accurate solutions
    tcrain4x4[OP] likes this.
  14. Sep 22, 2021 at 5:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nevermind I see the OP is in a first generation...
  15. Sep 22, 2021 at 5:33 PM
    Clearwater Bill
    Billy
    Largo Florida
  16. Sep 22, 2021 at 5:33 PM
    tcrain4x4
    terry
    Arkansas
    2001 tacoma 4x4 trd
    fabtech lift
