Tacoma SR5 vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pspurlin25, Dec 12, 2023.
  1. Dec 12, 2023 at 7:52 AM
    pspurlin25
    pspurlin25 [OP] New Member
    Pat
    Tacoma SR5
    I have owned a couple of Tacomas but the last two have had an annoying vibration and dealership keeps telling me it’s the tires even after putting two sets of new tires on. The first SR5 was used 2021 with 30k on it and the vibration was so bad they took it back and put me in a new 2023.
    After a month it is now doing the same thing. it’s very discouraging that a 40k plus vehicle would have these issues at all.
    the vibration occurs at various speeds and just drives you crazy.
    They say it’s normal but how can that be, if it’s normal they need to tell you this before you purchase
    Has anyone found what the real issue is?
    The dealership either doesn’t have a clue or they do and just know they don’t have a fix for it.
  2. Dec 12, 2023 at 7:55 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Warped rotors?
    Warped drums?
    Driveshaft out of balance?
    Are the tires road force balanced?
    Belle tire road force balanced mine for free and my vibs went away.
  3. Dec 12, 2023 at 8:02 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    At of all 3 Tacoma’s I’ve owned I only had that vibration issue with my 1st Gen with Goodyear Dura Trac tires. Went nuts checking the truck out ended up being the tires. Scrapped then never had a problem since. Go to a reputable tire shop and have them check out your truck.
  4. Dec 12, 2023 at 8:15 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Perhaps it might help if you were to describe the vibration you're experiencing.
    e.g. When braking. Thru the steering wheel. Thru the seat.
  5. Dec 12, 2023 at 8:45 AM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    You need to be more specific when this occurs like said above, Did you change the tire recently or are these the original causing the issue. You can’t blame Toyota if it’s a tire issue, as you know they don’t manufacture tires. Could it be a bad rim…sure but too many variables and more information needed to come up with a logical conclusion.
  6. Dec 12, 2023 at 8:58 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Mine vibrates a bit more than any of my other 3rd gens. Kinda a vibration through the floorboard, gas pedal, steering wheel when accelerating. Had the road force balance done and it helped some, we had a warm day over the weekend and noticed the vibration was vastly reduced. It seems to be a cold temperature related vibration on my truck
    embedded rock likes this.
  7. Dec 12, 2023 at 9:02 AM
    Brianz1001
    Brian
    too much to type
    Yours could be the compounds that make up the tire, if cold effects it, did they ever check the drive shaft out on your rig for the cause of the vibration.
  8. Dec 12, 2023 at 9:06 AM
    Bill400
    Bill400 Well-Known Member
    Bill
    2023/7170 (SR5, V6, DBL Cab, 4X2) Red, Advanced Tech Pkg
    OEM BSM/CTA retrofit complete
    Design issue. See: Driveline Operating Angle | Tacoma World
    It appears that Toyota exceeds Spicer guidelines.
    Also, angle should be the same on both ends of the same shaft segment. However, different segments can have different angles.
    Gfenza89 likes this.
  9. Dec 12, 2023 at 9:24 AM
    Gfenza89
    No they didn’t look at driveshaft
  10. Dec 12, 2023 at 9:57 AM
    CT Yankee
    CT
    Tires often develop flat spots when sitting overnight. It takes a few miles of driving the next day for them to dissipate. This tends to be more pronounced in cold weather.
    Both of my Tacomas have exhibited that behavior, with both the OEM tires and with the replacements.
