Tacoma Stalking, er...uh, Spotting, with Charlie™ (2nd Gen Edition)!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PennSilverTaco, Jan 19, 2017.
  1. Jan 9, 2020 at 5:01 PM
    #661
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Usually, I adhere to a strict rule of only posting Taco pics that I take, but sometimes I come across one online that's so good I just have to share it!
    Taco critter likes this.
  2. Jan 9, 2020 at 5:05 PM
    #662
    PennSilverTaco
    Charlie
    This is badass! Appears to be in Iceland...?
  3. Jan 9, 2020 at 5:34 PM
    #663
    PennSilverTaco
    Charlie
    @Mrtacoman88 ^^^^^^^^^
    How's this for "Some serious tires"?
    Taco critter and Junkhead like this.
  4. Jan 9, 2020 at 6:23 PM
    #664
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Noy bad, not bad at all. That thing looks like it will go anywhere.
  5. Jan 9, 2020 at 6:24 PM
    #665
    PennSilverTaco
    Charlie
    It looks like it's been modified for use in Iceland...
  6. Jan 9, 2020 at 6:33 PM
    #666
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Correct, thats how they mod their trucks over there. Pretty cool and different.
  7. Jan 15, 2020 at 9:20 PM
    #667
    PennSilverTaco
    Charlie
  8. Jan 19, 2020 at 4:02 AM
    #668
    PennSilverTaco
    Charlie
    Finally, back to some pictures I took myself!
  9. Jan 19, 2020 at 4:03 AM
    #669
    PennSilverTaco
    Charlie
    January 18th, 2020:
    Doylestown, Pennsylvania
    8217511E-EC7C-446F-96D5-63365D4F4783.jpg E5ED9EEB-8475-434F-B5E9-F43B765BDE85.jpg
  10. Jan 19, 2020 at 4:04 AM
    #670
    PennSilverTaco
    Charlie
    January 18th, 2020:
    New Hope, Pennsylvania
  11. Jan 19, 2020 at 4:48 PM
    #671
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I love this thread! If I’m ever passing through PA, I will be very disappointed if my truck isn’t posted here:D
  12. Jan 20, 2020 at 11:59 PM
    #672
    UnusuallyRegular
    UnusuallyRegular Active Member
    Joey
    Mobile, Al
    07 Reg Cab Tacoma V6 4wd
    1GR-FE/4wd conversion, Eibach suspension, TRD PRO 4Runner wheels, 11 X-Runner grill, TRD Sport headlights, 15 taillights, power window/ door lock/ keyless entry conversion.
    Hi, sorry for the late reply, I hardly ever visit the site. I have roughly 65 hrs tied up in swapping mine (includes the time of dismantling donor truck). It is not a bolt in swap, the engine mount pedestals have to be cut from the donor frame and welded in place of the 4 cyl mounts. There is a lot more that goes into it when you're doing the 4wd coversion as I did. It looks like you already have a 4wd, so there wouldn't be as much work that goes into it as mine did. Everything will work properly except the vsc. The 4 cyl ABS unit isn't compatible with the v6 engine's ecu, therefore you have to use the unit from the v6. So in using the unit from the v6, the ABS, trac, vsc, ect will work but due to the difference in wheelbase, the wheel-speed, steering angle, and yaw rate sensor inputs cause the truck to think it is in a skid and will engage vsc earlier than necessary. This isn't such a big issue because I can manually turn it off before driving. Otherwise it runs and drives like it was meant to be there from the factory. To answer your initial question, If you brought me your truck and a running donor truck, I'd do the V6 swap on an existing 4x4 truck for $2500, If I'm converting a 2wd prerunner to V6 and 4wd, I'd charge $3500 (2wd-4wd conversion will require a rc 4wd driveshaft in addition to the donor truck). If you're interested, message me on fb to discuss it further. BTW I'm located in Birmingham, Al and I'm a Toyota Certified Master tech with 16 years experience.
    JustDSM and MY50cal like this.
  13. Jan 21, 2020 at 12:14 AM
    #673
    UnusuallyRegular
    Joey
    Mobile, Al
    If you'd like to come visit and check out my truck you're welcome to. It'd give you a good idea of what to expect yours to be like.
  14. Jan 21, 2020 at 11:40 AM
    #674
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    When my 2.7 dies, or when it hits 500k(233 currently) I'll pay the the 2500 and fly you up to Maine to v6 swap my access cab!
  15. Jan 21, 2020 at 12:07 PM
    #675
    UnusuallyRegular
    Joey
    Mobile, Al
    Sounds good, but idk how the airline is going to feel about all of my tools and welder.
  16. Jan 21, 2020 at 11:53 PM
    #676
    Levalexi
    Southern Maine
    I'll have everything!
    I'm hoping by the time my engine dies, I'll have enough confidence, experience and some possible schooling to be able to do it on my own.
    I'm going to be attempting to v8 swap my ranger this year and I'm using the winter to gather the odds and ends I'm going to need.
    it's fairly easy swap, but I just started learning to do my own work on my vehicles this last year, but I'm confident I'll get it done
  17. Feb 14, 2020 at 9:13 AM
    #677
    PennSilverTaco
    Charlie
    2005-2008 DCSB TRD Sport 6-speed with base/SR5 wheels...
    February 14th, 2020:
    ECE2F4FB-49FE-4AA0-A647-2C6A07E77EA7.jpg 9AB9616E-8C1A-4875-94DD-C764E11E4FB9.jpg A7150667-FEA6-4BAB-9419-8F2F4E9EAE35.jpg
  18. Feb 15, 2020 at 7:16 PM
    #678
    PennSilverTaco
    Charlie
    February 15th, 2020:
    Warminster, Pennsylvania
  19. Mar 1, 2020 at 9:00 AM
    #679
    PennSilverTaco
    Charlie
    February 29th, 2020:
    Warrington, Pennsylvania
  20. Mar 25, 2020 at 5:25 PM
    #680
    PennSilverTaco
    Charlie
    2013 AC SR5 2.7L/auto 4x4 with 61K miles, for sale at Peruzzi Toyota...
    March 25th, 2020:
    Hatfield, Pennsylvania
    071C2EEB-4E7C-49FB-B089-9C6C8661946A.jpg 7EB7BE16-A916-4709-9B43-D31AF92E440A.jpg 20CF0EFC-2935-41E8-941B-8E86182B3F3A.jpg 460A2F4C-FA09-41C7-A509-07D92C8FB0E5.jpg
