Tacoma Stalking, er...uh, Spotting, with Charlie™ (2nd Gen Edition)!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PennSilverTaco, Jan 19, 2017.
  1. Jan 19, 2017 at 12:33 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I have taken so many pictures of Tacomas over the last few years that I have decided to organize them by generation now!
    CLICK HERE to reach the actual photos in this thread!
    CLICK HERE to see my new 1st Gen photo thread!
    CLICK HERE to see my new 3rd Gen photo thread!
    ORIGINAL POST (January 2017):
    THE SUBJECT OF THE THREAD IS ONLY A FANTASY!
    This however, is a true story...
    A few years back Toyota built a one-off 2WD extra cab Tacoma for SEMA show, outfitting it with a Tundra 5.7L V8 and giving the exterior a #95 Lightning McQueen theme. I have no idea how hard it would be to install, or even there would be enough room under the hood, for stuff like air-conditioning and power steering/power brakes.
    My 2010 Tacoma had just over 70K miles (just barely broken in!) at the time I started this thread and is pushing 152K now, so I do not have plans on ever swapping out the engine, even if I somehow become obscenely rich. If I do win the lottery or get rich somehow, I will keep my Tacoma. I will upgrade the stereo more (subwoofer, kick panel enclosures, etc), but other than that I will leave it as-is.
    Now back to fantasy:
    Anyway, putting in a 5.7L V8 is one thing... However, the space underneath the hood of all Tacomas is the same. That means once the computer/software and electrical stuff were replaced/upgraded to accommodate the V6, there would probably be no problem making a regular cab Tacoma with a V6 appear stock. When I say stock, I mean no parts would have to be specially made, and things like A/C, power steering, power brakes/ABS could be retained without any modifications.
    Obviously, this goes far beyond taking out the 2.7L and putting a 4.0L in it's place. Computer system/engine software and electric stuff will have to be swapped, and I'm pretty sure the A/C compressor is in a different spot with the V6 than it is with the 2.7L. The V6 radiator is probably larger than the 2.7L radiator as well.
    The transmission would have to be replaced as well, regardless of whether or not the truck getting the swap is automatic or stick shift. Again, it's probably pretty easy to put a 5-speed auto or a 6-speed manual into 2.7L truck.
    Don't know if the rear end/final drive ratio would have to be modified/replaced.
    Does this fantasy seem like it could be made into a reality?
    UPDATE (July 2019): It has been two and a half years since I posted this! As of this posting, my truck has over 101K miles and got a significant stereo upgrade in March-April 2018 (4th aftermarket head unit in less than 2 years, 2nd component speaker system in 5 years, plus a subwoofer and amplifier)! Not including the backup camera and various materials (wiring, sound deadening, etc), I have about $600 in my stereo as of right now. Let's just say it sounds a lot more expensive than it actually was!
    UPDATE (December 2020): I decided to merge a bunch of older threads into my 2nd Gen "Tacoma Stalking with Charlie" thread...
    Kolter45 and Scribbles like this.
  2. Feb 10, 2017 at 8:45 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I'm pretty sure total chaos built one. it was a full on race truck, but I would imagine everything would fit in place (maybe a little bit of fab). I think the 2.7 only gets the 4.10 dif, and the 4.0 has 2. 1 with locker, 1 without (not sure of ratios of all of them, I know mines 3.73) not sure about gearbox, but with $ you can make anything work. As far as the computer goes, I don't know. I can install a lift kit or bumpers, but can't wire a light bar in. Wires and electronics are my weakness
    BassAckwards likes this.
  3. Feb 10, 2017 at 8:54 PM
    ilovich
    ilovich Well-Known Member
    Daniel
    Los Angeles
    2011 MGM Reg Cab 5-Speed 4x4
    Leaves in the bed
    DrFunker likes this.
  4. Feb 10, 2017 at 8:59 PM
    Pigpen
    Dan
    Northwest Montana
    In 08 or 09 it was a factory option.
    PennSilverTaco[OP] likes this.
  5. Feb 10, 2017 at 9:02 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Of course it possible.
    Doing so with a 5 lug truck? Likely the bigger question.
  6. Feb 10, 2017 at 9:02 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    I know this question's been bandied around on here a couple of times previously, but unfortunately no one's stepped up to spend the money on such a project. My feeling is that it should be a bolt in. When you consider the fact that the X-Rubber is a 5 lug access cab, everything that goes into making that vehicle should be a bolt-in on a regular cab.
    Personally, I think a V-6 regular cab would be a wicked little truck. Why don't some of guys quite bolting on new do-dads and make this thing happen, lol.
    Oreo Cat likes this.
  7. Feb 10, 2017 at 9:35 PM
    Oreo Cat
    One of these days I'll get a 2nd tacoma, this one a reg cab just for this purpose..
  8. Feb 10, 2017 at 9:50 PM
    BKill
    Bill
    College Station, TX
    I've had this mental build/fantasy going for quite some time of building a hot rod Tacoma. Sometimes it's a RC X-Runner with a supercharged 4.0 and other times it's a RC 4X4 with a 1st gen Tundra V-8. All I need to make it happen is time, money, and skills, lol.
  9. Feb 10, 2017 at 11:30 PM
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    Look at Tundra 5.7L v8 4x4 regular cab short bed and put on trd supercharger. A bigger brother of v6 reg cab tacoma.
  10. Feb 11, 2017 at 12:49 AM
    Oreo Cat
    Please don't talk about that.. I need to get it out of my head before I become overly tempted..
    jv_74 likes this.
  11. Feb 11, 2017 at 8:37 AM
    PennSilverTaco
    Charlie
    Does my truck have a 4.10 diff from the factory?
  12. Feb 11, 2017 at 1:45 PM
    Oreo Cat
    I look into it a little bit more, i read that the 5 lug has a 3.31 diff and the 6 lug 4CYL comes with a 4.10. Still not 100% sure
  13. Feb 11, 2017 at 2:25 PM
    PennSilverTaco
    Charlie
    That's a random number. I'm surprised it doesn't have a 3.42 or a 3.55
    Oreo Cat[QUOTED] likes this.
  14. Aug 8, 2017 at 8:24 PM
    PennSilverTaco
    Charlie
    @MikieSwartz
    August 6th, 2017:
    I spotted this significantly damaged 2nd Gen driving around the Carlisle Fairgrounds on the last day of the 2017 Truck Nationals.
    The guy you see in the pictures owns a local dealership and bought this Tacoma from an auction for next to nothing. The previous owner flipped it onto its side and the insurance company wrote it off as a total loss.
    The owner, his kids, and his Min-Pin puppy: TruckNationals2017Day3 2192.jpg TruckNationals2017Day3 2193.jpg
    From the front: TruckNationals2017Day3 2194.jpg
    And, parked on the showfield a short time later: TruckNationals2017Day3 3061.jpg TruckNationals2017Day3 3062.jpg TruckNationals2017Day3 3063.jpg
  15. Aug 8, 2017 at 8:51 PM
    007PNWtaco
    007PNWtaco Well-Known Member
    Isael
    2010 silver tacoma
    Nice, do you know how much he had bought it for?
  16. Aug 9, 2017 at 8:50 AM
    PennSilverTaco
    Charlie
    Sadly, no...
    I forget whether he said he was going to totally repair the body or just drive it as-is. Either way, the truck had not been officially inspected for the purposes of being issued a rebuilt/salvage title, and wasn't technically street legal yet...
    Luckily, a dealer tag is an easy way to get around that!
  17. Aug 9, 2017 at 8:55 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Looks rough.
  18. Aug 9, 2017 at 9:04 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    How did he "bring it back to life?" Looks like he just put the key in the ignition and started driving it as-is.
    1mike1888, Justinlhc, Large and 4 others like this.
  19. Aug 9, 2017 at 9:07 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Right I clicked on this thinking there would be a Before and After photo's
    spitdog, Large, 12TRDTacoma and 5 others like this.
  20. Aug 9, 2017 at 9:07 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    I was waiting for the before and after pics. But the after never came. I feel robbed.
