Tacoma starting problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gunner1488, Apr 29, 2017.
  1. Apr 29, 2017 at 7:33 AM
    Gunner1488
    Gunner1488 [OP] Member
    Luke
    2000 Toyota Tacoma
    I have a 2000 Tacoma. Drove fine. Next day nothing. It was dead. Cleaned and tighten battery cables. Now the alarms come on when you open the door. I cleared the alarms but nothing happened when I turn the key to start but the alarm comes on again. Pulled the battery and took it and had it tested it is good. Don't know where to go next.
  2. Apr 29, 2017 at 7:37 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Welcome!! I can't help you out, but I did let the mods know to move it to the correct sub forum so you'll get a better response.
  3. Apr 29, 2017 at 7:41 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Does the horn work, headlights. interior dome lights ? Check fuses for starter ,etc.
  4. Apr 29, 2017 at 7:58 AM
    Gunner1488
    Luke
    2000 Toyota Tacoma
    All fuses are good. All lights and horn goes off
  5. Apr 29, 2017 at 8:21 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Factory or aftermarket alarm? Try using key to unlock and lock driver side door 3 times.should clear it. If not now the fun. There should be a switch somewhere. Push in while turning key.might be under dash or on kicker panel.might also be the Lil light on dash push it and turn key
  6. Apr 29, 2017 at 8:25 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    There's another way, but it's risky.
  7. Apr 29, 2017 at 8:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If it's a manual, you could try bump starting it. I've had to do that a couple times in my old '88 nissan.
    lucky13don likes this.
  8. Apr 29, 2017 at 2:07 PM
    Gunner1488
    Luke
    2000 Toyota Tacoma
    It is a factor alarm. Push button is on the dash. Unlocking door three times. Did not work. Pushing the button and turning the key did not work. Pushing the button six times did not work. ??
  9. Apr 29, 2017 at 2:08 PM
    Gunner1488
    Luke
    2000 Toyota Tacoma
    Battery is good. And will not jump off.
  10. Apr 29, 2017 at 2:18 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    sounds like an immbolizer set up. disconnecting the battery long enough to reset the ECU will activate the system.
    You'll be able to put the key in turn on all electrical systems lights, radio etc but when you turn the key you get nothing.
  11. Apr 29, 2017 at 2:18 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    disconnect negative battery post, turn key on then re attach battery post. its risky..
  12. Apr 29, 2017 at 2:23 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    im not at fault if you fry something. and all fuse and relays are good? check the starting fuse/relay. this doesnt add up..hmm
  13. Apr 29, 2017 at 2:27 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    terminals are tight, clean? shouldnt have a immobilizer. least my year doesnt. no aftermarket alarm, theres no alarm horn under the hood right? something isnt right, tap starter while someone turns the key.and if its a auto trans try starting in neutral.
  14. Apr 29, 2017 at 2:43 PM
    Gunner1488
    Luke
    2000 Toyota Tacoma
    Ok I tried starting in neutral cleaned all terminals and replaced the 40 a fuse. Still won't work.
    Fuergrissa likes this.
  15. Apr 29, 2017 at 3:35 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    who tested the battery? whats the voltage? you tapped the starter? your sure theres no aftermarket alarm,cause factory didnt come with a light on the dash..that i know of.
    keakar likes this.
  16. Apr 29, 2017 at 7:05 PM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    @Gunner1488 solving technically issues online is hard behind a keyboard so you gots give us as much info as possible.
    0) use the search tool and look for existing thread relating to your own problem
    1) did you do anything to the truck between the driving fine and starting issue?
    2) are you the original owner? How new is the truck to you? (Cuz sometimes previous owners leave little surprises:annoyed:)
    3) issue in detail, you put the key in and exactly what happens? Lights work but no crank or turns over and dies
    4)are you getting any codes ?
    5) if your not sure if you have an aftermarket part/component post a pic.
    The better the detail the quicker the answer.
  17. Apr 29, 2017 at 8:44 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Gotta be the starter or a aftermarket alarm. .only other thing I can think of.or battery is not fully charged.strange. .
