Tacoma Steering Rack Boot Repair with Glue ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Jul 23, 2025 at 8:51 PM.
  1. Jul 23, 2025 at 8:51 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Anyone found a split boot repair for steering rack boots or have you repaired steering rack boot with glue ?
    Also read that someone used flex tape and a heated screwdriver and that melted the 2 pieces of rubber back together.
    Anyway anyone used any these methods which you think is easiest?
    My boot broke in one place but I was thinking just adding grease to the hole and trying to reseal it not sure I'll be able to get new boot in time before go out of town.
  2. Jul 23, 2025 at 9:15 PM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    No idea. Never heard of such a thing.. is it a hole? Rip? Cut in half? What are we talking about here?
  3. Jul 23, 2025 at 9:28 PM
    TacoBell07
    Four door 2wd Taco
    Probably about 3-4 inch tear. It leaked out what looked like oil almost but I guess was just really old grease, thought it was power steering fluid at first but it was not.
    Oily but not oil im assuming old grease mixed with water. Truck has 337K on it now it was original boot probably.
  4. Jul 23, 2025 at 9:32 PM
    Bishop84
    Bishop84 Well-Known Member
    If the boots are torn its usually because the rack is leaking oil. Nothing will fix it, new boots would be a bandaid.
    danarello likes this.
  5. Jul 23, 2025 at 9:38 PM
    TacoBell07
    Four door 2wd Taco
    Right now it will be band aid I have to go on a trip Im not replacing a rack before I go at worst it will be a boot replacement which i was trying to avoid.
    Also I adjust the alignment before and never loosened the inner tie rod clap so that could have caused the boot to become overstressed and contributed it to breaking prematurely possibly. The alignment I did was only about 10,000 miles ago.
    As for the rack leaking if that were the case my power steering fluid should have changed and its not low its Full where it already was.
  6. Jul 23, 2025 at 9:38 PM
    Goosie0080
    North East
    Ya. That many miles? How old? Things are just adding up? But you just want to seal it till you get home or something? I guess just gorilla tape it.. but ya. That rack gotta go. I just did mine a few years ago.. rust got to it
    TacoBell07[OP] likes this.
  7. Jul 23, 2025 at 9:46 PM
    TacoBell07
    Four door 2wd Taco
    Basically, yes! Thats why I was looking into videos where people used blue Loctite gel glue as a temporary fix although it was on a CV joint but still might work. Now you're talking bro Gorilla tape that the primal solution I was looking for, righteousness.
    The fluid that was leaking was kinda brown and rusty colored looking, power steering pump has leaked for last 10 years at least but never had to top it off til this year.
    But youre thinking my rack is leaking internally I guess and causing it to leak into the steering rack boots?
    What happened to your rack did it stop turning or it just leaked so bad you could not keep any power steering fluid in it anymore ??
  8. Jul 24, 2025 at 4:19 AM
    nevertoomanytacos
    nevertoomanytacos Taco Fan
    3rd Gen
    Fixing broken stuff on a road trip is usually 3x more expensive and takes at least twice as long....
  9. Jul 24, 2025 at 7:50 AM
    TacoBell07
    Four door 2wd Taco
    Hey Moose man how is it possible for rack to leak fluid into boots but my power steering level not change in resvioir?
  10. Jul 24, 2025 at 2:19 PM
    danarello
    danarello Active Member
    Dan
    San Diego, CA
    2007 White Tacoma 4cyl 2.7L 2D
    Hey Tacobell07, I just asked the parts man at a Toyota Dealer the cost of a new Rack & Pinion unit and he quoted $840.00! He said NEW ones are not available only Reman! Mine is leaking Power Steering Fluid too! But the reservoir wasn't too low. I also have a torn passenger side boot. The CCN says it's not worth it to repair the boot (bellows) because the leak is internal and a new boot will just start leaking in a couple of weeks.
  11. Jul 24, 2025 at 3:08 PM
    BigTang
    BigTang Well-Known Member
    C
    2022 SR
    i'm still trying to figure out why we would fill the boot with grease.
    danarello and Goosie0080 like this.
  12. Jul 24, 2025 at 3:54 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    If your rack is seeping, which is common on older Tacomas, the fluid will often collect inside the boot over time and make the leak look worse than it really is. RockAuto sells replacement boots for as little as six bucks. They're not OEM, but they're much better than leaving a torn boot that allows water and debris in. Throw on a cheap boot, clean everything up, and keep an eye on the leak. That way, you'll get a better idea of how bad it actually is and how soon you'll need to deal with the bigger job of replacing the rack.
  13. Jul 24, 2025 at 4:51 PM
    Suarezabraham
    Suarezabraham Active Member
    Monterey, CA
    2014 Tacoma double cab 4x4
    Happened to mine was able to fix with a zip tie to hold it in place
