TACOMA STILL RUNNING HOT AFTER CHANGING T-STAT AND FAN CLUTCH....PLEASE HELP!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Feb 1, 2011.
  1. Feb 1, 2011 at 5:42 PM
    TacomaPilot2004
    TacomaPilot2004 [OP] Active Member
    Miami, FL
    2004 Tacoma V6 4x4 Crewcab
    Hello,
    I have a 2004 Tacoma 3.4L V6 4x4 that has been running hot. I tried changing out the t-stat and installed a new Toyota t-stat, but later that day, it began to heat up again.
    Then, my friend came over and noticed the fan was not blowing enough air. It was obviously spinning, but I hadn't realized how little airflow was blowing until we compared it to another Tacoma. So that was the second thing I did. I changed out the fan clutch, and now had a great amount of air flowing through. It ran great last night and all day today, but then just a few hours ago, the needle began to rise again. I was parked, so I quickly revved up the engine to 1500RPM and turned on the heat full blast, and the temperature quickly came back to the middle.
    I am so disappointed with this problem as I am the biggest fan of Toyota trucks, and this was the first time I ever bought one from a dealer. It runs absolutely great, except for this problem. Oil is great in color and level, coolant is full and has never leaked. I have no idea what to do next, and do not want to change another good part unnecessarily.
    Please help!!
    Thanks!! :)
  2. Feb 1, 2011 at 5:43 PM
    George Rockwell
    George Rockwell Well-Known Member
    Tacoma with a ARB bull bar
    very fast
    why didn't you go with a electric fan ? Could be air in the system? I have had that problem with German cars
  3. Feb 1, 2011 at 5:52 PM
    BIG MoFukin SERG
    BIG MoFukin SERG Well-Known Member
    Serg
    Los Angeles
    '09 MGM TRD Off Road
    5100's set at 2.5", Blacked-out badges, CB, Drop-in K&N
    May sound stupid but have you checked the engine oil level? The engine will run hot if the level is too low.
  4. Feb 1, 2011 at 6:03 PM
    TacomaPilot2004
    Miami, FL
    Ok, going to check the oil level right now. By the way, should I check it when its cold, when its hot, when its running???
    And how do you "burp" the cooling system?
  5. Feb 1, 2011 at 6:09 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Easy question first. Did you install the thermostat with the "jiggler" or valve to the top? That helps let any air out. Also, did you let it run with the radiator cap off for a fair amount of time? (Letting any air out also) Next check and see if the temp sending unit is clean and working(not grounding ) I had a VW that always told me I was overheating, turns out the wire to the sending unit was grounding to the block sending a false signal to the thermostat
  6. Feb 1, 2011 at 6:26 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    :confused::p
  7. Feb 2, 2011 at 4:27 AM
    HogTaco
    HogTaco Well-Known Member
    Northwest Arkansas
    2011 Access Cab 2.7 2WD AT
    Bed Mat, OEM Running Boards, Ultra-Gauge.
    I went through the same thing with my 1995 Nissan truck. Thermostat, then fan clutch. Finally bit the bullet and replaced the radiator. Problem solved. You can see flow in a bad radiator that is partially blocked.
  8. Feb 2, 2011 at 7:46 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    before you do that you should check your water pump for hairline cracks not very easy to see by eye but it is very possible cause that has happened to me before replaced everythiing then realized its just the water pump. pull i off and shine a flashlight into the intel and should show any signs of hairline cracks
  9. Feb 2, 2011 at 12:44 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Is it burning coolant,or looseing coolant, head gasket maybe. Did you have the radiator cap presure tested?
  10. Feb 7, 2011 at 7:07 AM
    TacomaPilot2004
    Miami, FL
    Hi everyone,
    Thanks for the input. I just now fixed the problem..FINALLY!!!
    So aparently, the lower radiator hose was very old and weak, and it had been collapsing due to the suction pressure from the water pump. I NEVER noticed it before, but I also had no idea that that was something to check for. I changed it out and it's now running great. Not a single sign of overheating. In fact, the needle seems to be even lower than the middle now!! :)
  11. Feb 7, 2011 at 2:01 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I h8 that you use all CAPS in every thread title that you post.:rolleyes:
    otis24 likes this.
  12. Feb 7, 2011 at 3:26 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    he must be a salesman give him a break
