Tacoma Stuttering when coming to a stop!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Charlie76, Feb 11, 2013.
  1. Feb 11, 2013 at 3:28 PM
    Charlie76
    Charlie76 [OP] New Member
    south carolina
    2001 Toyota Tacoma
    I'm having a problem with my yota, the dealership i took it to didn't know how to fix the problem. When I come to a stop at slower speeds the truck "stutters" it's like the brakes are catching intermittently, but I know it's not the breaks. Anybody out their know about this problem?
  2. Feb 11, 2013 at 8:06 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    do you have ABS?
  3. Feb 12, 2013 at 5:58 PM
    Charlie76
    south carolina
    2001 Toyota Tacoma
  4. Feb 12, 2013 at 6:07 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Extended cab? Check the driveshaft center bearing for excessive play. [​IMG] Check engine and trans mounts, too.
  5. Feb 12, 2013 at 7:05 PM
    dentaco76247
    dentaco76247 Registered Mud Abuser
    Greg
    Justin, TX
    97 Tacoma xtra cab 4x4
    4Runner bucket seats, Upgraded headlights Blistein 5100s Blacked out Grille
    warped rotors??
  6. Feb 12, 2013 at 7:10 PM
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    My old S10 did this, I took it somewhere and they trimmed the rotors and it was fixed. Costed $100 though..:mad:
  7. Feb 12, 2013 at 7:12 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Do you feel the brake pedal pulsate when it stutters?
  8. Mar 6, 2013 at 4:11 PM
    outdoorames
    outdoorames Member
    NorCal
    Toytech Ultimate Lift (set at 3"), OME Dakar leafs, 265/75/16 DuraTracks, Deck Plate Mod, UltraGauge, Kenwood head unit
    This is what my '97 is doing (stock with ABS). Any further ideas?
  9. Mar 7, 2013 at 10:20 AM
    tacoma04
    Bruce
    Tennessee
    Under normal braking, this is usually warped rotors. Your ABS will do this if it is a panic stop, but it normally won't with normal braking.
  10. Mar 7, 2013 at 11:42 AM
    outdoorames
    outdoorames Member
    NorCal
    Interesting. I'll have to look into that. I have no other vibration when braking and the ABS engaging is inconsistent though sometimes very unexpected (normal braking into a turn or over a small bump...neither of which would I expect the wheels/brakes to lock up or skid). It seems overly sensitive. Thanks for your response!
  11. Mar 8, 2013 at 12:35 PM
    Voyager
    Voyager Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    Lube the drive shaft fittings?
  12. Apr 12, 2013 at 2:21 PM
    cscook1911
    cscook1911 New Member
    Cory
    Mt. Juliet, TN
    '01 Double cab 4WD
    Hate to bring up an older thread but did you ever figure out the issue?
  13. Apr 16, 2013 at 12:35 PM
    outdoorames
    outdoorames Member
    NorCal
    This may be coincidental, but I haven't had the same over-sensitive ABS issue since replacing the suspension (Toytec Ultimate Lift with Dakar Leafs).
  14. Apr 16, 2013 at 12:40 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    I had a shutter too and its fixed now. I don't know much about all this but since I got my tires balanced it has gone away.
  15. Oct 8, 2013 at 12:47 PM
    Charlie76
    south carolina
    2001 Toyota Tacoma
    It is odd the problem i was having, just simply went away for these past couple months. I ended up dropping it off at a shop (didn't have time to look into it myself) they didn't find anything wrong with it themselves. So i kind of figured it worked itself out, but for the past month or so it has come back and is doing the same as it was before.
    It's almost more of a "catch" now when just about at a full stop.
    On gravel or on Slick roads the breaks will simply lock up. So i have to be sure to pump the breaks.
    Getting a bit worried now being winter and snow is almost here.
    I will set some time aside and check out the rotors, and everything else and see if i can't find something this time. I'll let you guys know. (Let me know if y'all have any more ideas as well)
  16. Oct 8, 2013 at 3:00 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    How do you know its not the rear brake shoes grabbing?
  17. Oct 10, 2013 at 8:36 AM
    Charlie76
    south carolina
    2001 Toyota Tacoma
    If it is the rear brake shoes grabbing how would I go about fixing it?
