Tacoma sucks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaBanana, Apr 16, 2021.
  1. Apr 16, 2021 at 2:37 PM
    TacomaBanana
    TacomaBanana [OP] Member
    Tacoma sucks
  2. Apr 16, 2021 at 2:46 PM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Spray a anti-mold treatment up the drain pipe.
    Worked wonders for me.
  3. Apr 16, 2021 at 2:48 PM
    TacomaBanana
    Tacoma sucks
  4. Apr 16, 2021 at 2:50 PM
    Sand_In_My_Taco
    NOR*CAL
    Honestly it came like that when I bought it as a CPO.
    I used a foaming spray, that comes with a plug so that you can properly foam up the (condenser?) from the drain pipe.
    Any auto store will have it.
    You specifically want the one with the rubber bit on the end, I tried another where I sprayed it in while the fan was running, and couldn't get it where it needed to go.
  5. Apr 16, 2021 at 2:52 PM
    Sand_In_My_Taco
    NOR*CAL
  6. Apr 16, 2021 at 2:52 PM
    TacomaBanana
    Tacoma sucks
  7. Apr 16, 2021 at 2:54 PM
    Sand_In_My_Taco
    NOR*CAL
  8. Apr 16, 2021 at 2:55 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Some people recommend to turn off the circulation maybe 20-30 minutes before arriving at your destination. After you get rid of the smell in the first place. This will help prevent future odors from developing.
    Dirk Diggler and Drahcir like this.
  9. Apr 16, 2021 at 3:03 PM
    Drahcir
    Drahcir Well-Known Member
    Orange County, CA
    2017 TRD OR 4x4 DCSB Quicksand
    Exactly this. If you keep recirculating air, you'll end up with that musty smell. Every so often I'll just turn off the recirculating feature and put the fan onto lowest setting with AC on. This lets fresh dry air pass through and prevents any mold build up.
  10. Apr 16, 2021 at 3:11 PM
    In2Ndo
    In2Ndo Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    This can happen to most cars if you don't ever use the heater and run the A/C most of the time. the best fix I found is to run the heater once in a while on the hottest setting. just for a few minutes at a time. I'm on my 5th tacoma and never had an issue with this. but I did in other vehicles.
  11. Apr 16, 2021 at 3:11 PM
    TacomaBanana
    Tacoma sucks
  12. Apr 16, 2021 at 3:19 PM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    Any vehicle with an AC system is prone to it. You just have to turn off recirc here and there. It's dumb that Toyota set recirc to be default when you turn on the AC, but it is what it is.
  13. Apr 16, 2021 at 3:23 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I've never had a vehicle do it, other than the Tacoma. I usually just spray Lysol on the intake on the cowl. I should try the foaming cleaner though
  14. Apr 16, 2021 at 3:25 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    The key is to turn off ac before you get home and keep the fan on without recirc on to dry out the coils. youre welcome
  15. Apr 16, 2021 at 3:25 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    I've never owned a vehicle where recirculation was the default. Very "interesting" choice, Toyota.
  16. Apr 16, 2021 at 3:42 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    This.
    I turn mine off about 2 or 3 minutes before I get home to park.
    If it's hotter than hell where you live, just turn off the ac/recirc and run normal air to dry it out. Started doing this and didn't have an issue.
  17. Apr 16, 2021 at 3:53 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    When the AC is turned on, the AC condenser will get wet with condensation from the humid air passing through it, if you turn the AC off and run the fan for 10 minutes as you approach your destination the moisture will evaporate and mold won’t grow on it.
  18. Apr 16, 2021 at 4:52 PM
    TacomaBanana
    Tacoma sucks
  19. Apr 16, 2021 at 4:55 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I've noticed it, but mostly when I first start using it for the year. It seems to go away after that. Haven't noticed it in a few weeks. Noticed it at the start of last summer as well, but it also went away.
