Tacoma suddenly having issues starting, but will start eventually.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOMABROKESOMEHOW, Oct 10, 2020.
  1. Oct 10, 2020 at 12:01 PM
    TACOMABROKESOMEHOW
    TACOMABROKESOMEHOW [OP] Member
    So about a week ago an issue suddenly started where the truck (2007 Tacoma 4.0) would not start. You can hear the starter, but won't run. The battery tested fine. All electronics work. After running around to get a code reader and coming back and messing with the truck trying to get codes (no codes were found).. the truck suddenly started right up and ran as normal. The truck turned off and started back up plenty of times after that. Come today when I try to start it up the issue has returned. I don't know what it could be. Any ideas? Thanks.
    Edit - four warning lights are on the dash. Engine, battery, oil, and tire pressure. All appear when this problem occurs.
    Edit 2 -
    I fixed the issue. Apparently my battery connections were corroded JUST ENOUGH for the starter to not work. Unfortunately, this was realized after trying a new starter and so now I have a brand new starter at 160k miles. Thanks for all the help.
  2. Oct 10, 2020 at 12:04 PM
    Masshole_And_His_Taco
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    Starter fully cranks the engine? I'd be checking spark and fuel
    12TRDTacoma likes this.
  3. Oct 10, 2020 at 12:04 PM
    PS, welcome to TW! Sorry trouble brings you, but glad you joined!
    Larzzzz and Thuguon2.7 like this.
  4. Oct 10, 2020 at 12:05 PM
    Taco-Obsessed
  5. Oct 10, 2020 at 12:09 PM
    TACOMABROKESOMEHOW
    All the starter does is click until it finally works as if there was no trouble at all.
  6. Oct 10, 2020 at 12:10 PM
    Sounds like you need a starter then. I had this happen intermittently for 6 months before it finally died. Sometimes went weeks without happening, just spinning the wheel of fortune and gambling on not hitting the dead spot.
  7. Oct 10, 2020 at 12:14 PM
    TACOMABROKESOMEHOW
    I just find it odd that all four lights I mentioned (oil, tire pressure, engine, battery) come on when the issue occurs. Did you experience the same? Makes me thing it's something else that affects the starter.
  8. Oct 10, 2020 at 12:15 PM
    That's just the startup sequence, they turn off once the truck is running. if there are no codes (active or stored) then you're fine in that regard. Replace starter and report back.
    TnShooter likes this.
  9. Oct 10, 2020 at 12:16 PM
    TACOMABROKESOMEHOW
    Okay, will do. Thanks.
  10. Oct 10, 2020 at 12:18 PM
    If you don't mind my asking, where are you located?
  11. Oct 10, 2020 at 12:19 PM
    TACOMABROKESOMEHOW
    Near Baton Rouge in Louisiana
  12. Oct 10, 2020 at 12:20 PM
    Ahh okay. Check out some of the local/ regional threads on here if you're in need of assistance or a recommendation for a shop.
  13. Oct 10, 2020 at 12:22 PM
    TACOMABROKESOMEHOW
    Okay, thanks.
  14. Oct 10, 2020 at 12:30 PM
    My pleasure, good luck!
  15. Oct 10, 2020 at 12:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    First thing I’d do is check the battery voltage when this happens.
    Then check it while trying to crank the truck.
    That way we can be fairly sure it’s not an intermittent battery problem.
    Here is a video on the process.
    https://youtu.be/Km6MNRYeEEY
    If the battery checks good, I’d move on to the Starter.
    The first place to look is at the battery to starter wire, the big one.
    Make sure it is CLEAN, and the battery terminals.
    The clicking sound would indicate the solenoid is likely getting power.
    There for the problem is likely in the starter.
    If it were me and, I want to be sure before I threw a starter at it,
    I’d make sure the battery is good.
    Check that there is power to the starter. Big wire.
    And then see if I’m getting power to the solenoid.
    (The clicking make me fairly sure you’re getting power to the solenoid)
    My opinion is: It is the starter. (If the battery is good)
  16. Oct 10, 2020 at 12:43 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Starter drawing to many amps, overloading the solenoid, breaking the circuit. AS stated above, seems to be the starter.
  17. Oct 10, 2020 at 1:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your problem is the starter solenoid contacts are burned. You can replace them in an hour or two for less than 40 dollars.
    The click you hear is the starter relay engaging, but the solenoid doesn't make contact so the starter doesn't turn.
    You can buy the contacts and plunger new from Nations Starter and Alternator for about 30 - 35 bucks. Much cheaper than hundreds for a rebuilt POS from Autozone etc.
    https://www.nationsstarteralternator.com/Starter-Rebuild-Kits-s/37.htm
    Check this video for rebuilding the solenoid on the starter.
    https://www.youtube.com/watch?v=qwokxzjlYcQ&feature=emb_logo
  18. Oct 10, 2020 at 3:54 PM
    TACOMABROKESOMEHOW
    TnShooter and Taco-Obsessed like this.
  19. Oct 10, 2020 at 4:03 PM
    eon_blue
    Azusa, CA
    We need a mod to change your username to TACOMAFIXEDNOW haha
  20. Oct 11, 2020 at 5:06 AM
    Gearheadesw
    Davenport Fl
    Post nunber 15 should have helped, oh well, new starter at 160k isn't a terrible thing.
