Tacoma Suspension TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaBuzz, Apr 10, 2010.
  1. Apr 10, 2010 at 8:59 PM
    TacomaBuzz
    TacomaBuzz [OP] Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Hey everyone , i just recently learned of a Toyota TSB issued a while back to address weak rear shocks/leafs. I have a 2005 DCAB LB SR5 and it only has the 3 leafs. I just emailed toyota but with 68K on the clock im not sure if they will replace them... here's hoping, anyone have the leafs/shocks replaced recently in their tacoma ?
  2. Apr 10, 2010 at 9:14 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Search away and you'll find hours of reading on this subject.
    Also, the TSB is considered warranty work that is limited to 3yr/36,000 miles.
  3. Apr 10, 2010 at 9:26 PM
    TacomaBuzz
    CT
    Toyota has very good customer service though and i'm hoping they will honor the TSB regardless.
  4. Apr 11, 2010 at 7:18 AM
    dexterdog
    Oly WA
    2012 F150
    Read the numerous threads on this site about this subject. It doesn't hurt to try but you'll most likely be denied due to the age and mileage of the vehicle.
  5. Apr 11, 2010 at 9:34 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Ride Rite Air Bags and Bilstein 5100's is how I solved my 2005 DC Tacoma soft rear end... Complained about the bottoming-out to the service dept. at my dealer, no help offered... I didn't know about the TSB, and so I took it upon myself to fix it... and after some debate on progressive leaf springs (Deaver) vs. Air Bags (Ride Rite Air Springs), I went with the Ride Rites.
    Took them off when I traded the '05 for then '10, in case they hadn't fixed the springs after 5 years (the new ones are better)! Still have them in a box in my garage... waiting to see if I want them on the new truck.
  6. Apr 11, 2010 at 9:36 AM
    TacomaBuzz
    CT
    That is a SWEET setup
  7. Apr 11, 2010 at 9:48 AM
    David K
    With a puff of air you can quickly adjust firmness and ride height... I was usually set at 25 psi, but 15-45 psi was my range... No need to have any more, seriously!
  8. Apr 11, 2010 at 11:00 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    TSB applies to prerunners
  9. Apr 11, 2010 at 11:28 AM
    GT150
    GT150 Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    My 2 wheel drive Prerunner, gets the TSB springs put on this week
