Tacoma switched from Drive to Neutral with acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoman100, Sep 12, 2019.
  1. Sep 12, 2019 at 1:05 PM
    Tacoman100
    Tacoman100 [OP] Active Member
    hi,
    Yesterday I pushed on the accelerator harder than usual from stopped position, and the strangest thing happened: the shifter went into Neutral. I did this again a little later and noticed that it went into Neutral for a second and just came back into drive by itself. The first time it did it, I had to pull over and put it back into drive since I didn’t know what happened.
    It’s a Gen 1 Tacoma 01-04 variants and it has an auto transmission.
  2. Sep 12, 2019 at 1:15 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I've never heard of this before, so hopefully someone else can chime in with more info.
    I wonder if the shifter linkage is bent or something. Does the actual shift lever pop into neutral?
    Gunshot-6A likes this.
  3. Sep 12, 2019 at 1:19 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Engine torque causing the shifter linkage to move
    You need to check motor mounts and transmission mounts for structural damage
  4. Sep 12, 2019 at 1:34 PM
    Tacoman100
    Yes it does. So putting it back into drive just fixes it.
    I know for sure the bushings in the Shifter is worn out, because the shifter has play, and a few months ago I tried removing the key from the ignition, but it wouldn’t go out of the ACC position until i wiggled the shifter.
  5. Sep 12, 2019 at 1:34 PM
    Tacoman100
    Ouch... any idea what could cause this and maybe how to check this?
    US Marine[QUOTED] likes this.
  6. Sep 12, 2019 at 1:46 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Since you didn't specify what year 1rst gen you have this generation of Tacoma's can 15 to 24 yrs old and have 200k miles plus . Parts do wear out and that holds true for engine and transmission mounts
    To check them ...
    visually look for torn or separated rubber isolator pads
    Cracks in the frame rails or mounts
    To test them use a pry brand see if you can move the engine or transmission
  7. Sep 12, 2019 at 1:49 PM
    jbrandt
    Justin
    Start it, and pop the hood. Then give it a few revs by manually moving the throttle cable. It should move a little bit but not that much. I've never really measured that, but I would think less than an inch for sure.
    Also just a visual inspection of the motor and trans mounts. Look for cracking in the rubber.
  8. Sep 12, 2019 at 1:52 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Also a symptom of a bad engine or transmission mount is feeling vibration from the floorboard . Also a clunking sound on acceleration
    Tacoman100[OP] likes this.
  9. Sep 12, 2019 at 1:54 PM
    Tacoman100
    Okay I’ll try to see what I can do tonight. Any idea if this is an easy fix or will it require a professional transmission mechanic?
  10. Sep 12, 2019 at 1:55 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    It can be repaired easily in your driveway
  11. Sep 12, 2019 at 1:55 PM
    Tacoman100
    Will do. What is the possibility of it just being the physical shifter having too much play?
  12. Sep 12, 2019 at 1:56 PM
    Tacoman100
    A
    Awesome! May I solicit a YouTube video or possible pictures from you to show me what I’m looking for?
  13. Sep 12, 2019 at 1:57 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Yes a worn shifter can cause problems also
  14. Sep 12, 2019 at 1:58 PM
    Tacoman100
    Okay, all this sounds like a good learning opportunity for me. I’ll knock this out this weekend.
  15. Sep 12, 2019 at 2:00 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    There's many YouTube videos showing how to diagnose and replace motor mounts
  16. Sep 12, 2019 at 2:01 PM
    Tacoman100
    On it.
  17. Sep 12, 2019 at 2:01 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    I'd believe worn shifter or trans mounts. Alot of guys that off-road have this problem when hitting hard bumps when offroading, it'll pop itself into neutral.
    Tyler Lacasse likes this.
  18. Sep 12, 2019 at 5:47 PM
    Glamisman
    Glamisman Well-Known Member
    just curious here... is this a column shift automatic or a floor shift automatic?
  19. Sep 12, 2019 at 6:11 PM
    Tacoman100
    It’s on the floor. Are any Tacoma’s column shifts?
  20. Sep 12, 2019 at 8:19 PM
    Glamisman
    yes, one of my residents has one... odd looking, very odd looking.
