Tacoma tail light wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reinhardtius, Oct 4, 2019.
  1. Oct 4, 2019 at 10:35 AM
    Reinhardtius
    Reinhardtius [OP] Well-Known Member
    07 Base 2.7L 5SP
    Folks,
    I am installing FJ40 tail lights on my 07 Tacoma. They will sit below an aluminum bed that I just installed.
    Two questions:
    1. Can anyone help me confirm the function of each colored wire?
    Passenger side:
    white/black = ?
    green = ?
    blue/yellow = ?
    red/white = ?
    blue = ?
    Driver side:
    white/black = ?
    green = ?
    blue/black = ?
    red/white = ?
    blue = ?
    2. I wired the FJ40 lights to the connector, following the colors on the OEM tail lights. I notice that there is a ground (white/black) for EACH bulb, but on the FJ40 lights, there does not appear to be a ground.
    As they are wired currently, when I turn on the lights, both the tail and turn lamps come on. When I turn on the emergency lights (hazard flashers) both the tail and turn lamps come on.
    Your assistance much appreciated. Thanks,
  2. Oct 4, 2019 at 11:18 AM
    Reinhardtius
    07 Base 2.7L 5SP
    Forget it y’all. I’m going to drill out the FJ40 bulbs and install the OE Tacoma bulb bracket assemblies.
  3. Oct 4, 2019 at 11:44 AM
    Muddinfun
    Muddinfun Well-Known Member
    White/black will always be ground on these trucks. The reason you got wonky results is because you had no ground connection.
    Passenger side:
    white/black = ground
    green = tail
    blue/yellow = right turn
    red/white = reverse
    blue = brake
    Driver side:
    green = tail
    blue/black = left turn
    red/white = reverse
    blue = brake
    TnShooter likes this.
  4. Oct 4, 2019 at 7:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
