Tacoma thinks it’s stuck in Reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by venezian, Jul 28, 2023.
  1. Jul 28, 2023 at 12:38 PM
    venezian
    venezian [OP] Well-Known Member
    Los Angeles
    2022 7545E
    I moved my truck to back into my driveway and the beeping in the dash wouldn’t stop.
    I have a manual trans.
    I also have a pioneer headunit with maestro setup I’ve had for several months now, maybe 6 months never had an issue.
    I went through the settings in the HU and it’s basic settings. Turning off the bsm or parking sensor did not stop it.
    I disconnected the negative battery terminal for a few minutes.
    When i plugged it back in, the HU displays the reverse camera and the reverse lights are on.
    i cant get out of the screen to adjust anything.
    not sure what else to do or check.
  2. Jul 28, 2023 at 12:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    So it's not actually stuck in reverse, the truck just thinks it is?
    Seems there may be a stuck or broken reverse switch.
  3. Jul 28, 2023 at 12:49 PM
    venezian
    Los Angeles
    2022 7545E
    correct. It thinks it’s in reverse.
  4. Jul 28, 2023 at 12:57 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Try unplugging the reverse switch on the transmission.
    Clearwater Bill and wayupnort like this.
  5. Jul 28, 2023 at 1:04 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    i had the same issue when i installed Android headunit (cartrimhome) in my manual trans truck. after looking on the facebook group i found other manual trans owners having the exact same issue. even after swapping canbus units and replacing headunit with another still had same issue. ended up just buying a completely different radio (dasaita) and it worked as it should even with the exact same canbus harness so it was a compatability issue with the radio itself.
    edit: reread post and seen yours was working for 6 months prior so probably not the same issue after all and i only had probably with the reverse camera not shutting off.
  6. Jul 28, 2023 at 1:44 PM
    venezian
    Los Angeles
    2022 7545E
    where can I find the reverse switch?
    I just reprogrammed the Maestro kit just in case. If that doesn't do it, I will remove reverse cable.
