Tacoma ticking under acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lita4x4, May 2, 2016.
  1. May 5, 2016 at 1:56 PM
    TacoMan33
    TacoMan33 The little idiot that could
    David
    Texas
    2006 PreRunner 4.0 V6 SR5 ACLB
    JBA C/B | Apline door speakers | Kenwood radio
    OP, check see if it might be coming from the cats. Ive heard of this before and it was the cats. Do this by putting your truck on JACK STANDS, not jacks. One its up on 4 solid stands, with drive gear engaged, have someone rev it while youre near the cats. Also, while the engine is going, check to hear if it's coming from the engine bay. Might be a bad bearing or possibly a belt. Or maybe it your drive train. Rev that thing and pin point the source of the noise. Once you do that, youre halfway done to getting it fixed.
  2. May 5, 2016 at 2:01 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Toyota TSB EG021-06 APR 06 - Ticking Noise Between 2,000-2,500 RPM
    Toyota Supports ASE Certification Page 1 of 1
    EG021-06
    Title:
    EXHAUST TICKING NOISE
    Models:
    ’05 – ’06 Tacoma
    Technical Service
    BULLETIN
    April 7, 2006
    Some customers may experience a ticking or tapping–type noise from the engine area
    at 2000 – 2500 rpm during acceleration that is most noticeable after a cold soak.
    New exhaust manifolds have been developed to minimize this condition.
    2005 – 2006 model year Tacoma vehicles produced BEFORE the Production
    Change Effective VIN shown below.
    MODEL ENGINE PRODUCTION CHANGE EFFECTIVE VIN
    Tacoma 1GR–FE 5TE*U##N#6Z217578
    PREVIOUS PART NUMBER CURRENT PART NUMBER PART NAME QTY
    17140–0P010 17140–0P070 Manifold Assembly, Exhaust, RH 1
    17150–0P010 17150–0P070 Manifold Assembly, Exhaust, LH 1
    17173–0P010 Same Gasket, Exhaust Manifold 2
    Replace both LH and RH exhaust manifolds.
    Refer to the Technical Information System (TIS), 2005 or 2006 model year Tacoma
    Repair Manual: 1GR–FE Engine Mechanical: Partial Engine Assy: Replacement.
    OP CODE DESCRIPTION TIME OFP T1 T2
    EG5027 R & R Exhaust Manifolds 1.6 17140–0P010 91 41
    Applicable Warranty*:
    The Remove & Reinstall (R & R) of the Exhaust Manifold (P/N 17140–0P010 and
    17150–0P010) due to the attached Catalytic Converter, is covered under the Toyota
    Federal Emissions Warranty. This warranty is in effect for 96 months or 80,000 miles,
    whichever occurs first, from the vehicle’s in–service date.
    * Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
    ENGINE
    Introduction
    Applicable
    Vehicles
    Production
    Change
    Parts
    Repair
    Procedure
    Warranty
    NAAC3TACO and digitaLbraVo like this.
  3. May 5, 2016 at 3:17 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    There was a TSB on the V6 to reflash the ECU to fix pinging.
  4. May 5, 2016 at 3:31 PM
    TacoMan33
    David
    Texas
    This could be the problem
  5. May 5, 2016 at 3:33 PM
    digitaLbraVo
    Workd when mine did it around 30-40k miles. I thought it was getting warmer and just starting to ping so I started running 91 octane then it kept getting warmer and kept pinging worse and worse. Saw the TSB was released a week or so before I went into the dealer, so early he didn't even know it existed.
    Hasn't happened since.
  6. May 5, 2016 at 3:34 PM
    TacoMan33
    David
    Texas
    OP, try that. Go to a dealer and have your ecu flashed
  7. May 5, 2016 at 7:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That is where I work.
  8. May 6, 2016 at 6:06 AM
    Jaab
    Jaab Well-Known Member
    Captain Wiggles
    SW Ontario
    2005 Double cab short box 4x4 TRD Taco....
    OME 887, Dakars ARB bull Bar, M8000 winch,ABS mod, Locker mod, fog lights anytime mod, COMFY BMW sport seats, tweaked Airbag emulator,
    weird then?
