Tacoma Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nfcarrier, Apr 3, 2012.
  1. Apr 3, 2012 at 4:26 PM
    nfcarrier
    nfcarrier [OP] New Member
    Upstate NY
    2010 Tacoma
    New guy here, member of the over 60 set, first post.
    I just picked up a 2010 Tacoma 4x4, reg. cab, 4 cyl-5 spd manual.
    The prior owner put on 265/70 R17 tires.
    I was wondering how this will affect gas milage and does it make the speedometer read wrong?
    I don't plan on any wild off roading other than it will be handy in deer season. Plus I do live in snow country (usually) so it 4x4 will be handy then.
    Debating whether to keep these clodhoppers or go back to stock tires.
    tia
    Neal:D
  2. Apr 3, 2012 at 4:37 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    Manitoba
    08 TRD
    It seems to me that those 'clodhoppers' are of the small variety around here. A lot of guys actually run wider. I do not believe the upsize from stock affects the speedo significantly. I think there is a formula around the site somewhere that helps to calculate the difference . Anyone? I run that tire size in a C load range. I find they provide me with a much better ride quality.
  3. Apr 3, 2012 at 4:39 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Howdy and welcome. According to my handheld GPS, those same size tires on mine make my speedo read approx 2 mph low at 65. My mileage did decrease when I put these on, but I also levelled it (Bilstein 5100's set at 1.75) and am carrying a heavy cap with rack (drag) so I can't put it all on the tires. Now that I have an Ultraguage, I'm able to see what I'm doing and have been able to bring my mpg's back up to around 17 with 90-95% highway driving at 65-70 mph. I'm running an '11 AC/4.0l/6-spd.
  4. Apr 3, 2012 at 4:44 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    It's about a 3.5% difference in height & speed over stock, which is about the amount my speedometer is off (reads high) when running stock size tires. Running 265/70R17 makes my speedometer read dead on with my GPS. I figured they would kill the gas mileage, but oddly enough didn't seem to make any difference to me. I have '07 DCSB V6, don't think it makes any difference though.
    David
  5. Apr 3, 2012 at 4:45 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    welcome!
    should not change MPG by much at all. i’m going to a 265/75 r16 soon. witch i know is 1” taller than the 265/70R16.
  6. Apr 3, 2012 at 4:46 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    didn't affect my mileage either. I'm still getting 18.5-19 city and 20-21 hwy
  7. Apr 3, 2012 at 5:06 PM
    tommyg29
    tommyg29 Well-Known Member
    South Miami, FL
    12 DCLB PreRunner Sport
    Remember its not the height but technically the circumference of the tire that changes the speedo readings. 2 pi r, or about 3.14159 times the height of the tire is your rolling circumference, give or take. There are lots of factors involved in mpg, like the weight of the wheel/tire, rolling friction, etc.
    Try this calculator. There are lots of handy wheel and tire calculators out there. Just have to search:
    http://www.performanceprobe.com/ind...nceprobe.com/misc/index.php?do=calc&page=tire
    Check some tire sites also for good reviews. I use tirerack.com and discounttire.com. They usually have lots of customer reviews.
  8. Apr 3, 2012 at 5:41 PM
    Canazes9
    David
    Texas
    Actually it doesn't matter. The height of the tire (diameter) or the circumference, the % difference will be the same and therefore the % error will be the same.
    %difference in height = % difference in circumference = % diff in speedometer.
    No reason to calculate circumference unless it just makes you happy to do so.
    David
  9. Apr 3, 2012 at 6:02 PM
    tommyg29
    South Miami, FL
    You are right, but..its the rolling distance (circumference) that is a more precise measurement.
  10. Apr 3, 2012 at 6:21 PM
    Canazes9
    David
    Texas
    There are no measurements being made in this discussion. It's all calculated based on the tire size, multiplying the calculated tire diameter by 3.14, 3,140,000 (or any other number) doesn't change the precision of the calculated speedometer error at all. None. Zero. Nada. Zilch.
    :D
    David
